Z06 C-6 Shocks on C-5
Old Jul 17, 2011 | 08:25 AM
The Yav's Avatar
The Yav
Default Z06 C-6 Shocks on C-5
Gentleman,
I have a chance to buy a set of new C-6 Z/06 shocks. Will the shocks fit my 2000 C-5? Thanks in advance.
Old Jul 17, 2011 | 08:36 AM
egrand333's Avatar
egrand333
yes
Old Jul 17, 2011 | 09:15 AM
baxsom's Avatar
baxsom
direct fit, read the installs here about torque values on the bolts.
Old Jul 17, 2011 | 09:26 AM
Rob Petyo's Avatar
Rob Petyo
Originally Posted by egrand333
yes
I use them too!
Old Jul 17, 2011 | 09:46 AM
WICKEDFRC's Avatar
WICKEDFRC
.....But are the C6Z shocks better than the C5Z shocks or Bilstein sport? I have heard there are slight differences in the characteristics.
Old Jul 17, 2011 | 01:37 PM
Dans99C5's Avatar
Dans99C5
I put c6z shocks on my 99 vette with 90-ish thousand miles, along with c6z51 sway bars and it made a vast difference.
Old Jul 17, 2011 | 06:50 PM
The Yav's Avatar
The Yav
Thanks,,,I currently have Z06 springs, 04 shocks, and sway bars. The current 04 shocks are a little mushy for being 6 years old. Can the C-6
Z/06 brakes fit?,,,I can also buy the whole suspension package,,,he went with coil overs on his Z.
Old Jul 17, 2011 | 07:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
QUOTE"
Man,,,,,,,,,,,,, ,, You will think you have a NEW CAR!
Purchase a crow bar. You will need it to pry the GRIN off your face!
If you have the base suspension, the ZO6 stuff will be another VAST improvement!!!!!
BC
Old Jul 17, 2011 | 10:27 PM
vms4evr's Avatar
vms4evr
If you already converted it from base to C5 Z06 suspension. Then just get a new set of the 04 Z06 shocks to freshen it up. They are matched to those springs and bars.
Old Jul 18, 2011 | 08:03 AM
dbaker's Avatar
dbaker
Best U/G I've done was installing C6Z shocks on my (63K) 02Z.WOW.....what a diff.
Got mine from Gene at GMpartshouse for approx $250.
\db2
carolina
Old Jul 18, 2011 | 08:27 AM
MR.G.'s Avatar
MR.G.
I put C-6 Z06 shocks on my 1998 Vert. They only had 18k mi. on them, along with them I put on the C-6 Z06 front sway bar, and a Z51 rear 31/24 mm respectively. I was disappointed. It didn't tighten it up like I thought it would. I had a C-6 with Z06 sway bars front and rear but with them I put on Bilstein Sports. Now that was a MUCH better combo in my opinion.
Thanks,
Mike
Old Jul 22, 2011 | 04:05 PM
Pfadt Racing's Avatar
Pfadt Racing
The attractive and inexpensive option of C6Z06 shock replacements comes up often here on CF. One of the problems with suspension upgrades from factory components is that a lot of the results will be subjective. We took a LOT of CF member feedback on C6Z06 shocks when we outlined the requirements of the new Johnny O'Connell OE-shock upgrades. CF users expressed that they often had a much harsher ride on the Z06 shocks, which led to an "unsettling feeling" that caused the rear of the car to be nervous etc. On top of this, they also have the reputation of being very soft in terms of platform, or chassis response to steering inputs. These were the targets that we set out to eliminate in the OE-replacement JOC shocks. If you are considering a true "upgrade" to your shocks, you should for sure take a look at the JOC option because they carry ALL of the OE benefits in terms of durability, fit, finish and longevity, with the added feature of having a responsive and "firm when necessary" damper valving. This all leads to a more predictable, controllable Corvette that has a smooth street ride to it.
For those cars that are starting to get up there in mileage the entire Johnny O'Connell package replaces key items in the suspension that are sometimes overlooked, like replacement endlinks and sway bar bushings. After installing the Johnny O'Connell package your C6 becomes just easier to drive fast, while remaining comfortable on the street.
One of our Johnny O'Connell customers jbsblownc5 put together a video of his drive across Death Valley to Spring Mountain for a track day out there. He came away extremely happy with the package as a whole. We are getting that kind of positive feedback from a lot of people who have gone with the JO package!
jbsblownc5's Pfadt Race Engineering Johnny O'Connell Thread
Old Jul 23, 2011 | 03:19 AM
thetaxman's Avatar
thetaxman
If I'm going to go through the labor of changing shocks I sure wouldn't use oem anything
Old Jul 23, 2011 | 10:10 AM
japc5's Avatar
japc5
Originally Posted by Bill Curlee
QUOTE"
BC
With everything Bill said.
On my 98 I went from the F45 shock and base sway bars/links to C6Z06 shocks and C6Z51 sway bars, with metal end links and poly bushings. Different car, totally different absolutely amazing how it hugs the road on turns while pushing the comfort limits of the butt meter.
Old Jul 23, 2011 | 09:15 PM
NatB's Avatar
NatB
FWIW Bilstein Sports can be had for a tad over $330 plus labor.
Old Jul 24, 2011 | 12:13 PM
Acrespo1986's Avatar
Acrespo1986
i would just save up a little more and get coil overs . Thats by far the best suspension upgrade you can do.
To Z06 C-6 Shocks on C-5
