Oil level switch Info
Old Jul 17, 2011 | 11:18 PM
C5 Hunter's Avatar
C5 Hunter
Default Oil level switch Info
If you have ever needed to fix the Oil Level Switch due to the wires being melted, this migt help. I had to do this repair but my wire were gone at the plug, no way to repair . After trying to find a pigtail with no luck I noticed that the underhood light (that I was not using) is exactly the same . I ended up cutting off the plug end and spliced the wires and presto no more problem. I will now look for a repacement for the light just because I dont like to have anything not working .
Old Jul 17, 2011 | 11:48 PM
lucky131969's Avatar
lucky131969
....so you fixed one problem....by purposely creating another? The pigtails are readily available, and probably could have had one shipped to your door by Tuesday.......
Old Jul 18, 2011 | 12:12 AM
LoneStarFRC's Avatar
LoneStarFRC
From what I found it looks like your best bet is going to be an AC Delco PT-374 (GM # 12102747) connector pigtail for that plug.
HTH
Old Jul 18, 2011 | 12:14 AM
Jnape's Avatar
Jnape
I got a replacement connector for the OAT sensor at the dealership. $26.oo and had 12 " leads on it. It was even in stock.
To Oil level switch Info
