Chirp From Engine Torquing
Old Apr 26, 2002 | 09:04 AM
pburant's Avatar
pburant
Default Chirp From Engine Torquing
I searched the archives for both 'chirp' and 'squeak', but couldn't find anything like what I'm experiencing. I'm sure this is just an annoyance and not a functional problem, and a quick talk with my mechanic (he'll see the car on Monday) seemed to confirm that. Car in neutral (6 speed), if I quickly punch the gas about 1/4 and quickly let up, I hear a pretty loud chirping noise coming from somewhere outside the car. I haven't had the opportunity to have someone else sit in the car to work the gas while I listen. It's definitely not belt noise or intake whistle, and happens when the car is perfectly still. The car is a 2001 vert. and has 11k miles on it - all good weather miles. My mechanic believes I'm hearing the springs that support the exhaust chirp as the engine torques - he claims those springs are notorious for such noises. From everything I've been able to discern, this is a feasible explaination, but I wanted to check if anyone else has experienced this just in case it turns out to be harder to find than just some springs in need of a little lube.
Thanks for your help,
Pete
Old Apr 26, 2002 | 01:04 PM
davidfarmer's Avatar
davidfarmer
Default Re: Chirp From Engine Torquing (pburant)
It is possible, but if so should be easy to fix. The exhaust hangers are all easily accesible from under the car. Get the car on a lift and check around the center hanger springs, and especially where they pas the torque tube close-out panel (heat shield).
Dave
