Help with trans cooler
Old Jul 19, 2011 | 09:34 PM
Sick C5's Avatar
Sick C5
Default Help with trans cooler
Purchased the B&M 70264 from Summit which is a cooler that many forum members have said is a great cooler and has all the fittings for installation. I can't get the thing installed. I have my CAI, top radiator cover and front radiator cover off, I can't figure out how to mount the cooler with the zip ties, and I'm unsure where the fittings go. Do I cut my existing fittings that go into the radiator? Someone please help me, I'm so frustrated with this.
Thanks,
JR
Old Jul 20, 2011 | 01:29 AM
Sick C5's Avatar
Sick C5
Come on guys.
Old Jul 20, 2011 | 02:00 AM
SB99NassauBM's Avatar
SB99NassauBM
Yes this is a very good cooler, the stacked plate style is better than the tube and fin style.
You should be able to get these at local parts stores.
http://www.summitracing.com/parts/FLX-3910/
I mounted mine on the front of the A/C condenser. pull it up and away from radiator and swing it out a bit, that should give you enough room to carefully push nylon bolts through condenser and then through cooler putting rubber spacers in between. There are mounting brackets available but I used nylon bolts.
I would NOT cut the lines. just be sure the supplied fittings are 5/8 –18 thread. I would test fit before moving on.
The top line coming out of the radiator cooler is the return line going back to tranny. I have mine set up to go through radiator cooler first then external cooler and back to tranny.
Unscrew factory fitting going into radiator (top one) Screw fittings from kit in radiator and fitting in metal line. Run hoses in kit from metal line to external cooler, then from rad to cooler. be sure not to pinch lines when you run them, the straighter the lines are the better.
Hope this helps , good luck
Old Jul 20, 2011 | 02:15 AM
reactor2's Avatar
reactor2
Thanks,
JR
***Don't cut any of the existing lines.***
Its pretty simple, here's how I did mine:
1) Mount cooler to bottom/center of air conditioner condenser, attach with supplied mounting straps to condenser (not through to radiator in case you want to remove the radiator).
2) Mount with cooler inlet tubes facing up. You can mount in either this position or sideways. If you mount up you can pre-fill the cooler with trans fluid. I mounted mine with inlets facing up.
3)Top transmission line attached to radiator is return line.
a) Remove radiator return line.
b) Insert supplied male pipe fitting (with barbed end) into radiator.
c) Run hose from radiator to transmission cooler (either inlet if mounted in upright position or top inlet if mounted sideways).
d) Run hose from "exit" inlet on trans cooler to aluminum line you removed. Use the supplied female fitting (with barbed end).
*Hose routing
I routed the hose via the top right corner of radiator.
*before you connect the hose to the aluminum transmission line fill the cooler with fluid through this line. It probably won't take much more than a half a quart. You can probably do this with a funnel and gravity but I used a cheap fluid pump I picked up at the parts store.
Hope this helps.
Old Jul 20, 2011 | 06:41 AM
Sick C5's Avatar
Sick C5
Thanks for the quick responses guys. I'm assuming the nylon bolts are the zip tie looking things? I have four of them, am I supposed to just push them through the fins on the condenser?
I have 4 fittings, none of which will screw into my radiator, they're all too small. I'll post pics of them and take measurements when I get home from work tonight.
Old Jul 20, 2011 | 09:02 AM
reactor2's Avatar
reactor2
Just push those nylon mounting straps through the fins in the condenser. I pushed them through from the back of the condenser ( so they are anchored at the condenser side).
My kit came with everything I needed to install the cooler. Yeah, post pics of what you have.
Old Jul 20, 2011 | 09:18 AM
reactor2's Avatar
reactor2
I just replaced my cooler (the one you have) with the larger model. I might have the two fittings that you need but I am highly doubtful. I probably threw them out... Yeah that was stupid. Had you posted this thread 3 days ago i would have then for sure. I'll double check the garage just to be sure. Talk about timing.
Old Jul 20, 2011 | 09:55 AM
reactor2's Avatar
reactor2
I just checked the garage, I definitely have the fitting that goes into the radiator, when I get home from work I'll see if I can locate the fitting that allows you to attach the hose to the factory line (I'm still doubtful however that I will have it).
Old Jul 20, 2011 | 04:53 PM
SB99NassauBM
http://www.summitracing.com/parts/HDA-390/
These will work assuming you have rubber lines in your kit.
Old Jul 21, 2011 | 12:46 AM
Sick C5's Avatar
Sick C5
Here is a pic of the fittings that came with my cooler. They're all too small to thread into the top of my radiator, since none of the fittings worked, I didn't bother messing with the bottom radiator line.
Has anyone else had to special order fittings for 70264?
If you guys could find some fittings that you don't need, that would be awesome! I'd be so grateful! Just let me know if y'all have any extra fittings, or anymore advice!
Thanks so much,
JR
Old Jul 21, 2011 | 03:00 AM
reactor2's Avatar
reactor2
Thanks so much,
JR
The bottom two fittings look to be the ones you need. The male fitting goes into the radiator and the female is for the factory transmission line.
If those don't work I have the fitting that goes into the radiator but I must have thrown out the other. PM me your address and I can send it out if you'd like.
Old Jul 22, 2011 | 09:12 PM
Blow Torch's Avatar
Blow Torch
So are you running rubber lines??
I don't trust rubber lines and worm clamps. If they DO burst, slip, etc, you're STUCK
Went all braded lines and fittings on mine. Much more confident
Old Jul 23, 2011 | 11:13 AM
Sick C5's Avatar
Sick C5
Where did you order your lines from? I've never heard of anyone having trouble with the rubber hosing, but it's always nice to have options
Old Jul 23, 2011 | 12:58 PM
reactor2's Avatar
reactor2
Btw I ran rubber lines and a 3600 stall no problem, also ran rubber lines on a 5000 stall TH400 with rubber lines no problems.
I've also never heard of any problems with rubber lines.
Old Jul 23, 2011 | 05:23 PM
Blow Torch's Avatar
Blow Torch
Parts breakdown in post 6
I ran them from the connections located by the flywheel (look at the connector in the photo.)
BTW - YES, rubber can come off. One of the post I read when researching was from a member who had a line blow off and he lost his fluid. IF it does, you will be stranded, and I personally, want no part of that.
http://forums.corvetteforum.com/c5-t...-fittings.html
Old Jul 24, 2011 | 04:03 PM
Sick C5's Avatar
Sick C5
I bought these. They're the exact same size as the fittings that came with my trans cooler. They don't fit.
Old Jul 25, 2011 | 07:41 PM
reactor2's Avatar
reactor2
Bizarre. Although its sometimes difficult to gather anything from a picture, could you post a picture of the radiator and perhaps the fittings in the radiator?
To Help with trans cooler
Old Jul 25, 2011 | 08:30 PM
Sick C5's Avatar
Sick C5
I got your fitting today, thanks a lot, but it's the same as the others lol. I'm stumped.
Old Jul 31, 2011 | 03:04 PM
Sick C5's Avatar
Sick C5
Since I couldn't ever find fittings to attach to my return line and radiator, I just cut the return line and put two barbed fittings on. This is how my trans cooler is setup.
Transmission>Feed line>Radiator>return line> transcooler>transmission
Here's a pic of my set up:
http://i955.photobucket.com/albums/a...5/324060b7.jpg
Now here's my problem, my transmission is still getting hot as ****. It's been 100+ degrees here in Dallas for 29 days in a row. My trans just reached a new high of 253 degrees. Do I need a bigger cooler. I have the B&M supercooled 70264 and a 3800 yank stall.
Old Jul 31, 2011 | 03:08 PM
lucky131969's Avatar
lucky131969
Here's a pic of my setup. [IMG]http://i955.photobucket.com/albums/ae38/SickC5/324
060b7.jpg[/IMG]
Now here's my problem, my transmission is still getting hot as ****. It's been 100+ degrees here in Dallas for 29 days in a row. My trans just reached a new high of 253 degrees. Do I need a bigger cooler. I have the B&M supercooled 70264 a a 3800 stall.
Hmmm.....I understand the ambient temps are high, but if you just reached a new high temperature....after you installed the cooler.....do you think there may be a problem elsewhere?
