TCS/LDCM/RDCM codes
Old Jul 19, 2011 | 11:46 PM
billla's Avatar
billla
St. Jude Donor '14
Default TCS/LDCM/RDCM codes
Sounds like I need to have the Steering Wheel Position sensor replaced? Do at home? Cost to have done?
Starting throwing TCS codes C1287/C1288 about every other day.
Checking the codes also pulled up:
LDCM: U1064, U1069, B2282, B2284, B2262, B2264
RDCM: B2283, B2285, U1064, U1096
Thoughts?
Old Jul 19, 2011 | 11:51 PM
Bill Dearborn's Avatar
Bill Dearborn
The door codes are voltage level problems. The C codes tell you the voltage of the steering sensor is off. Maybe the C codes are due to an improper voltage supply to the sensor Vs a bad sensor. Check all voltage and ground connections and make sure something hasn't happened to the wiring in the door accordions.
Bill
Old Jul 20, 2011 | 12:03 AM
Jnape's Avatar
Jnape
Any wheel/tire changes lately? Have YOU ever had the car aligned? Is the steering wheel CENTERED?
Old Jul 20, 2011 | 12:36 AM
billla's Avatar
billla
St. Jude Donor '14
All good advice; thank you.
I'll start tomorrow - I think there's a FAQ on the grounds here somewhere if I remember correctly.
I pretty much always get a charging fault indication if it sits for a few days.
No tire/wheel changes. Car was lowered and aligned ~3 months ago. Steering wheel appears visually centered.
'03 Z06, BTW. 74K miles, all stock.
Old Jan 5, 2012 | 02:15 PM
billla's Avatar
billla
St. Jude Donor '14
Update - the battery was JUNK (original - I guess it was about time) and I changed it. I also cleaned the grounds as was noted elsewhere.
The codes persisted and I haven't had time to look deeper - and now I'm also throwing ABS codes C1265, C1283, C1287, C1288). So the full list of current codes is:
28
C1265
C1283
C1287
C1288
A0
B2262
B2264
U1064
A1
U1064
Am I correct in thinking that this points pretty clearly to the SWPS? Otherwise, I'll get out the multimeter and the factory service manual and start learning about this stuff
Old Jan 5, 2012 | 05:22 PM
sunchaser73's Avatar
sunchaser73
For your A0 and A1 codes:
U1064 is Loss of Comms with BCM => could be something with the wiring in the accordion tube or related to a junk battery
B2262 is Horizontal Position Sensor Fault => left side-view mirror
B2264 is Vertical Position Sensor Fault => left side-view mirror; The DCM monitors the supply voltage to the mirror positioning motor and triggers a fault if the voltage level is out of range. One possibility is that the circuit was not provided the correct voltage (4.0-5.5 VDC) because of the battery.
For your 28 codes:
C1265: LR Inlet solenoid valve malfunction => can be triggered if the EBTCM senses an open, shprt to ground or short to voltage in the circuit
C1283: Excessive time to center steering => the description in the service manual is pretty long, but the "summary version" is that the EBTCM uses inputs from the Yaw Rate sensor, Lateral Accelorometer and Wheel Speed sensors to determine when to start the steering wheel centering routine. If there is a large offset between the yaw rate sensor and the lateral accelorometer, the EBTCM will believe that the steering is off-center, and trigger the code after driving at 25mph+ for 10 minutes.
C1287: Steering sensor rate malfunction => do you have active handling (RPO JL4)?
C1288: Steering sensor circuit malfuntion => triggered when SWPS voltage falls outside the range 0.2-4.8 VDC
It seems to me that the battery might be a common factor amongst all the codes. If you aren't already aware of this, the C5 is very finicky about battery voltage. Now that you have replaced the battery, I would advise that you clear the codes and see which ones come back. Make sure your battery stays fully charged. A battery tender might not be a bad idea either. I use the CTEK Multi US 3300 model, and have had no battery/voltage issues since installing it.
Clear the codes, drive the car, check for codes and post up what you find.
Hope this helps.
Old Jan 6, 2012 | 03:30 AM
DeeGee's Avatar
DeeGee
Originally Posted by billla
Update .......
FWIW, I have the same TCS codes, specifically C1287 and C1288 but intermittent. If you've been doing a search you probably found some of my threads. Having done a lot of research I'm fairly sure it's the SWPS.
I have a SWPS waiting to go in but it's not an easy job as you have to pull the steering coumn.
Check post #35
http://forums.corvetteforum.com/c5-t...-sensor-2.html
Old Jan 6, 2012 | 03:16 PM
billla's Avatar
billla
St. Jude Donor '14
OK, cleared the codes today and now have just the following. Note that these come on immediately at start, every time.
28
C1265 H
C1287 H
C1288 H
Old Jan 6, 2012 | 03:24 PM
sunchaser73
Did any of those three codes come back as "current" during the last drive cycle?
Also - do you have active handling RPO JL4? There 2 different diagnostic procedures for C1287, depending on JL4 or no JL4.
Old Jan 6, 2012 | 08:19 PM
billla's Avatar
billla
St. Jude Donor '14
They show up as an "H C" after clearing - so both current and historical. They pop up now right at startup, every time.
I don't have active handling. I do have the FSMs...I figure I should probably run through the process this weekend if for no other reason than to learn to do it. I am not...an electronics guy, being fairly used to accidently letting the smoke out when I work with them. They appear not to work afterwards. Go figure.
Old Jan 6, 2012 | 08:20 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by 8VETTE7
Likely Steering wheel position sensor failure,
Before you replace it insure that the car is properly aligned and the when going down a straight and flat road that the wheel is centered. Both can cause issues like you are experiencing if the alignment is off and/or the wheel is not centered.
The car tracks straight no-hands, and the steering wheel appears visually centered. I did have the car lowered and an alignment done this summer, but it was after these issues surfaced.
Old Jan 6, 2012 | 11:11 PM
billla's Avatar
billla
St. Jude Donor '14
If your car is an 03 as your profile indicates you DO have AH. It is standard equipment on all C5's beginning in 2001. It was an option that began mid model year 1998 and continued as an option through the 2000 model year until it became standard equiment starting in 2001. When it was an option it had RPO identifier JL4.
http://www.corvettemuseum.org/specs/2001/features.htm
I'm aware I have active handling - I thought what was being referred to was the magnetic handling option thingie.
Sorry; honestly not all that famliar with C5 options, shamefully
Old Sep 3, 2012 | 08:18 PM
billla's Avatar
billla
St. Jude Donor '14
Update (finally). I replaced the SWPS today; took me about 5 hours but I was working very slowly and carefully...and I'm old and inflexible All the codes are clear.
I started getting C1214 about 3 months ago, so off to ABSFIXER my ECBM goes.
Would be nice if that's it for a while
Old Oct 7, 2012 | 09:50 PM
billla's Avatar
billla
St. Jude Donor '14
Recieved the EBCM back from ABSFIXER and installed - now I'm getting C1265. I'm checking in with Brandon as well, but thought I'd check in here.
From review of the manual and some online sources, this seems to be be in the same function that the surge protection "upgrade" is applied...? Did anyone else pop for this upgrade? Any issues?
Any thoughts on things to check while I'm waiting on a response?
Old Jun 24, 2013 | 04:42 PM
billla's Avatar
billla
St. Jude Donor '14
I thought I'd close this out with the final resolution - I am "code free"!
ABSFIXER found two burnt coils in my EBCM and repaired them for $150. I appreciate his willingness to look at it again and do a quick turnaround.
THANKS to everyone that provided information and guidance to get this resolved!
Old Oct 9, 2016 | 06:32 PM
vettelover8306's Avatar
vettelover8306
For your 28 codes:
Hope this helps.
hi there i know this can be a little bit crazy cause this post is 4 years old but anyway good to give some advices to c5 owners yes it seems like c5 corvette love to treat bad the batteries lol i was having these kind of issues in my 97 abs light , security light, traction control and hvac problems...once i cleared all the codes the car feels better about codes hvac blows nice ..it was another problem with the air it wasnt blowing hard enough but once i cleared the codes it started to work fine..yes it sounds crazy but something so simple can bring several issues..what i recomend is to clear the codes also why not to clean the battery terminals...
To TCS/LDCM/RDCM codes
