Rear Wheel Camber Adustment Question-Please Help!
Old Jul 22, 2011 | 04:20 PM
yellowLPEZO6's Avatar
yellowLPEZO6
Default Rear Wheel Camber Adustment Question-Please Help!
I need to adjust the REAR WHEEL CAMBER on my 2003 ZO6, and would like to know wether you need to disconnect the OUTER TIE ROD ENDS from the Wheel Hub / Steering Knuckle, PRIOR to making the CAMBER adjustments.
Thanks SO MUCH for your help.
yellowlpezo6
dwparrish2003@yahoo.com
Old Jul 22, 2011 | 08:03 PM
Solofast's Avatar
Solofast
No, you don't need to remove the rear toe links to adjust the rear camber, but the rear toe will change when you change the rear camber. If the rear camber adjustment has slipped, if you put it back to where it was the rear toe should be right again.
