Service abs. Service traction control
Old Jul 25, 2011 | 07:39 AM
lwd2000's Avatar
lwd2000
Default Service abs. Service traction control
What happened? Yesterday we went for a cruise for the day. When i started my car after dinner last night to come home i got this message. Drove home with the message then shut my car off and it cleared. Drove it this morning and it is still cleared. Am i good at this point or is something wrong? Thanks for any info.
Old Jul 25, 2011 | 06:04 PM
lwd2000's Avatar
lwd2000
Default Clarification
To clarify, i got the "service abs and service traction control" indicators last night for the first time but not coming on today. Is this normal? Why might it have happened? Thanks for input.
Old Jul 25, 2011 | 08:54 PM
02koolC5's Avatar
02koolC5
Post your codes, and what year car .... here is a link on what to do http://www.stengel.net/diccodes.htm
many members including myself have gone though this
Old Jul 25, 2011 | 09:29 PM
lwd2000's Avatar
lwd2000
Default Codes
2000 vert
Codes received in order:
C1243h
C1255h
B1001h
B2282h
B2284h
U1064h
B2283h
B2285h
U1064h
U1096h
U1064h
U1016h
This is all the codes given throughout the sequences. Thanks........btw is this a lot of codes????
Old Jul 25, 2011 | 09:34 PM
dougbfresh's Avatar
dougbfresh
Clear them ALL and see if any return-try to check right after the ABS warning comes on.
Old Jul 25, 2011 | 10:36 PM
drsvette's Avatar
drsvette
abs wheel speed sensors will clear themselves after a ignition cycle if the abs module sees that everything is sending its signal and all is okay, intermittent codes like that can be coming up for several reasons, ie possible wheel bearing issues just starting to happen, corroded connections, water if it has been raining in your area interfering with the sensor signal. check all the codes and evaluate what is actually happeneing, usually your traction control and active handling lights and code are set due to some abs wheel speed sensor issues.
Old Jul 26, 2011 | 12:57 PM
BigGun's Avatar
BigGun
None of those codes point to a wheel speed sensor. This is what gave you the service message:
C1243 BPMV Pump Motor Stalled
C1255 EBTCM Internal Malfunction
Clear them and hope you don't see them again. If they keep coming back it could get expensive.
Old Jul 26, 2011 | 03:44 PM
lwd2000's Avatar
lwd2000
Not what I'm wanting to hear. Is there a chance that all is okay and taken care of? Anyone had any experience with a situation like this?
Old Jul 26, 2011 | 04:39 PM
dougbfresh's Avatar
dougbfresh
There's always a chance-that's why you CLEAR them all and monitor the situation-if those codes return, it NOT a good sign. Many have had the same issues, hardly a week goes by without an ABS/TC thread.
Old Jul 26, 2011 | 04:42 PM
claytoncramer's Avatar
claytoncramer
Yes. It came to about $2500.
I have reason to believe, based on what I have read, that one of the difficulties involves the relays in the EBTCM failing because of lack of use. This is because the vast majority of Corvettes are simply never driven to the point where the ABS system gets regularly used. Some people have found that taking the car out onto a road where you can SAFELY do a hard stop that cycles the ABS several times will clear the problem. You may need to do this regularly.
At some point, the problem gets worse until it is solidly on--and then it is time to spend money, gobs of it.
The 2001-2004 EBTCM can apparently be rebuilt for about $500 I understand, and replacing it is not hopelessly difficult. But the 2000 and before? No way.
Old Jul 26, 2011 | 05:11 PM
siberian.mist's Avatar
siberian.mist
ive had that same light a couple of times and maybe just coincidence but i consider this all general maintainance and have not had lights since.
clean all electrical grounds in engine bay.
clean maf
clean throttle body
did the brake slam on wet road a few times
lights have not come on since.
might as well do those 4 things it wont do any harm
Old Jul 26, 2011 | 07:45 PM
doveboat's Avatar
doveboat
Are ABS & Active Handling still operable (in effect) while the lights are on ?
Ed
Old Jul 26, 2011 | 07:55 PM
dougbfresh's Avatar
dougbfresh
Ed
Not when the warnings are on.
Old Jul 27, 2011 | 07:20 AM
lwd2000's Avatar
lwd2000
clean maf
clean throttle body
What is the "maf"??? Are there threads here on cleaning the maf and the throttle body?
Old Jul 27, 2011 | 09:18 AM
dougbfresh's Avatar
dougbfresh
Mass Air Flow (MAF) it determines how much air is entering the engine by MASS so the rest of the system knows how much fuel and spark are going to be required.
Old Dec 3, 2011 | 12:54 PM
Boldcall's Avatar
Boldcall
Cruising
All I did was spin the right rear (loose gravel on the on-ramp). No error messages at the time. Stopped and parked the car for a quick grocery run, and when I came back and started again, I had STC/SABS messages in the DIC. Turned it off and back on, but errors persisted. Got home and came in the house and read this thread, then went back out to the garage and tried it again. Messages gone. Never underestimate the power of the Internet I am of course, still mystified but pleased at the moment.
Old Dec 4, 2011 | 07:33 PM
carhopper's Avatar
carhopper
I would start by getting the EBCM rebuilt. Also, clean the grounds behind the headlights. I just went through this. Bad grounds, 1 bad wheel sensor, and probably a bad steering angle sensor, but it hasn't resurfaced yet. There's a guy on ebay that rebuilds them for $50. I was looking into it when I had problems, but turned out to actually be the wheel sensor. http://www.ebay.com/itm/320790088250...S:1123&vxp=mtr
To Service abs. Service traction control
Old Dec 13, 2011 | 07:52 AM
1973convertiblevette's Avatar
My ABS and Traction control service lights come whenever I hit a rough bump or hole in the road. Do you think this is probably just the wheel ABS sensors? Because when I turn the ignition off and then back on, the code will not appear until another rough spot does.
Old Dec 13, 2011 | 08:05 AM
carhopper's Avatar
carhopper
Honestly It's not enough into to tell, but sure it could be. Try pulling the harnesses to the wheel sensors, cleaning the pins if necessary, and retensioning the female portion to make better contact. You can also put a meter on the EBCM connector to read the resistance and have a friend wiggle and manipulate the connector to see if you have intermittency.
Old Dec 13, 2011 | 08:07 PM
02koolC5's Avatar
02koolC5
Pull the codes on the car using the DIC and post them if any...kinda sounds like a grounding issue though. The codes would narrow it down to wheel sensor or steering sensor or EBCM
EDIT: http://www.stengel.net/diccodes.htm
