Headlights ?
Old Jul 25, 2011 | 08:08 AM
rickster86's Avatar
rickster86
6th Gear
Default Headlights ?
Ok, I know its in here somewhere, 1997 C5 headslight won't come on.
I have jumped at the connection under the hood where they go to the lights & motor. THE lights raised up no lights. Checked all the fuses #3 and #4.... Once they are up I can turn them off at the switch inside and they go down..... I also jumped to the lights and they work.
Also when I pull on the dimmer switch to flash them they come on...
I have dash,taillights .................
I am thinking the switch needs to be replaced??????
The switch is over $200. just want to make sure that is the problem!
Thank, in the DARK...
Old Jul 25, 2011 | 10:18 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I had a very similar problem with my Light. Replaced the MFS myself and it solved the problem.
Best of luck.
rr
Old Jul 25, 2011 | 11:12 AM
rickster86's Avatar
rickster86
6th Gear
Thanks, When you say MFS that is the headlight switch on the column? Just to make sure.....
Old Jul 25, 2011 | 11:15 AM
rickster86's Avatar
rickster86
6th Gear
I got it ! Thanks for your help!
Old Jul 25, 2011 | 11:26 AM
byronhunter's Avatar
byronhunter
You might try this
http://forums.corvetteforum.com/c5-t...f-replace.html
To Headlights ?
