LS6 or LS3
Old Jul 20, 2011 | 04:30 AM
XX's Avatar
XX
XX
St. Jude Donor '12
Default LS6 or LS3
Guys I would like some opinions , tomorrow I would like to make my mind up on the direction I would like to go. I can get either a new LS6 or LS3 for around the same cost except the added cost as listed below on the LS3. I know I would have to change the reluctor the 54x to a 24x wheel on the LS3 ,the 4x single bolt cam gear to a 1X , a few wire adapters and moving the sensors, not going the adapter module route. My plans are CAI/Lt/Cam and tune for a daily driver. Maybe a cam on the LS3 like a SpinMonster grind nothing to wild. Give me some opinions, back to a LS6 or move on to a LS3.
Old Jul 20, 2011 | 08:52 AM
sfc rick's Avatar
sfc rick
My opinion would be to ask the question....Which would be "easier" to install? Both are gonna have the same comparable Horsepower after the mods you pull. Which is going to be more expensive in regards to total costs?
If you are prepared to spend a little more and more time installing the LS3 and end up with about the same HP as your modded LS6 would have been......well that's food for thought!
Stock LS6 405hp
Stock LS3 436hp
That 30 hp diff goes away depending on the Mods you install on both.
Just thinking out loud.
Old Jul 20, 2011 | 09:08 AM
Dominic Toretto's Avatar
Dominic Toretto
The torque will of course be more noticeable with the LS3 with the greater displacement. The power may only be slightly better on with equal mods as stated above so, for a street car you will never notice the slight difference. Your best bet is to contact a tuner to see exactly what can be fished out of both with those mods. Also see if you can source some dyno graphs from both engines with those mods and compare power delivery as well.
-Alex
Old Jul 20, 2011 | 09:38 AM
GR8GAME's Avatar
GR8GAME
ls3.
Old Jul 20, 2011 | 09:42 AM
crainholio's Avatar
crainholio
You've made a pretty good list of adaptations needed for the LS3, but don't forget the PCM recalibration that will be needed. More cylinder volume, bigger injectors, etc. all will need to be reconfigured via tuning before the key is turned.
Old Jul 20, 2011 | 09:46 AM
chaase's Avatar
chaase
St. Jude Donor '12
I assume that the current motor is dead and buried which is why you are getting a brand new one. If you have to go completely new, then the LS3 will be superior because of the extra cubic inches.
Old Jul 20, 2011 | 11:02 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
bigger is always better IMO
Old Jul 20, 2011 | 12:19 PM
XX's Avatar
XX
XX
St. Jude Donor '12
One day I will have to change my nick here. I have been an old school guy until 05 with a long list of of having 60's-70's corvettes , 67-69 camaro's either running sb or bb . I got tired of going to the track pulling my car hauler with my last 68ss running race and all you guys most of the guys moved to driving the cars to the track running on pump fuel. The reason i am considering the LS3 is more torque in the lower rpm/extra cubic inches. If I go with the LS3 I also will have the LS3 Intake Manifold w/ Fuel Rails & Injectors setup. My current LS6 is still running strong and may keep it as a backup or sell it not sure at this time. I know I need the pcm tuned and will have to check who can take of that for me, will call Ragin Racin or Thunder Racing. It looks like most of you guys say go for the LS3 , getting close on pulling the trigger on the LS3. I will add I may a go SC one day but then I will have the bug to bad and have to upgrade the rest of the drivetrain.
Old Jul 20, 2011 | 12:41 PM
AU N EGL's Avatar
AU N EGL
LS3 with dry sump. LS6s are very hard to find
Old Jul 20, 2011 | 12:47 PM
XX's Avatar
XX
XX
St. Jude Donor '12
Will be a wet sump LS3, right now I can have either for about the same cost. Come on guys talk me into buying the LS3 or out of it as that's what I am leaning to doing. Let me add if I get the LS6 it would just sit there as a backup for now.
Old Jul 20, 2011 | 01:07 PM
AU N EGL's Avatar
AU N EGL
Can you find a crate LS6 ?
Old Jul 20, 2011 | 01:24 PM
XX's Avatar
XX
XX
St. Jude Donor '12
Yep
Old Jul 20, 2011 | 01:42 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by bad1968ss
Will be a dry sump LS3, right now I can have either for about the same cost. Come on guys talk me into buying the LS3 or out of it as that's what I am leaning to doing. Let me add if I get the LS6 it would just sit there as a backup for now.
There are a number of added cost going to the LS3, but that said, it would be my 1st choice. If you get the true dry sump version, it's 436 HP and has a steel in place of cast crankshaft. You will also need 24x to 58x converter, rework harness for knock and cam sensor location changes, also you will need to modifiy engine mounts or buy late model engine mount brackets. There are other things, but those are the bigger ones.
Old Jul 20, 2011 | 01:46 PM
AU N EGL's Avatar
AU N EGL
Yep
Then snap that baby up NOW
/Thread
Old Jul 20, 2011 | 01:55 PM
XX's Avatar
XX
XX
St. Jude Donor '12
Got that cover, guess I am just looking for the hell yes go that route over myself making up my own mind. But I do feel there would be gain advantage in torque with the LS3 and more if I mod more later on.
Old Jul 20, 2011 | 01:56 PM
XX's Avatar
XX
XX
St. Jude Donor '12
/Thread
Got you pulling for the LS6
Old Jul 20, 2011 | 02:08 PM
silver408z's Avatar
silver408z
I would go with the ls3. More potential down the road if he mod bug bites.
To LS6 or LS3
Old Jul 20, 2011 | 02:15 PM
XX's Avatar
XX
XX
St. Jude Donor '12
Thats why I have not pulled the trigger on either one yet...
Old Jul 20, 2011 | 02:18 PM
Dominic Toretto
Used or new?
-Alex
Old Jul 20, 2011 | 02:23 PM
XX's Avatar
XX
XX
St. Jude Donor '12
Originally Posted by AlexSmith
Used or new?
-Alex
New on either one
