help crankshaft
Old Jul 25, 2011 | 08:57 AM
calvette 11's Avatar
calvette 11
Default help crankshaft
I 'm sick of my engine throwing the crankshaft bolt out.I'm using a arp bolt now.Who makes a pin kit for the ls1 engine.
Old Jul 25, 2011 | 10:27 AM
bumble-z's Avatar
bumble-z
If you have a stock H/balancer.
Check with John. Member Bluvette1.
He has supplied many members with a resonably priced kit.
Good luck.
Old Jul 25, 2011 | 10:30 AM
sfc rick's Avatar
sfc rick
Is there some underlying reason it throws the bolt out? Just curious to know? I thought the bolt was a one time use thing.
Old Jul 25, 2011 | 10:38 AM
corvettebob1's Avatar
corvettebob1
When the balancer walks around the crank snout it will loosen the bolt.
This happens many more times then you can imagine that's why anyone that removes their balancer for any reason should pin it!
Old Jul 25, 2011 | 01:15 PM
calvette 11
Hi
It walked about five years ago.After ten passes Friday,I heard the sound and you could turn the bolt with your hand.I need to pin it,once and for all.
Old Jul 25, 2011 | 01:16 PM
calvette 11
Default damper
Good luck.
Can you pin a after market unit?
Old Jul 25, 2011 | 01:30 PM
sfc rick's Avatar
sfc rick
So it's a defect in the LS1 design? It can't handle the power.
I had to press on my pulley and then Torqued the one time use bolt. I guess I need to watch out and plan to fix what GM failed to do?
Old Jul 25, 2011 | 01:35 PM
bumble-z's Avatar
bumble-z
Give Bluevette1 a pm. (John)
He would know
Old Jul 25, 2011 | 01:37 PM
bumble-z's Avatar
bumble-z
It's a quite common problem.
Old Jul 25, 2011 | 03:33 PM
crainholio's Avatar
crainholio
Common when:
1.) The balancer wasn't installed with an installation tool, just shoved on w/ a bolt;
2.) The bolt wasn't torqued properly;
3.) The old balancer was reused and beyond useful life.
Not so common otherwise.
LS Vettes, on the other hand, have big problems w/ the balancer ring coming off the hub when the rubber insert gets old, even if the balancer has never been removed.
Old Jul 25, 2011 | 09:14 PM
Luv2Fly's Avatar
Luv2Fly
Does your balancer wobble? If so time for a new one as well. Common issue.
Old Jul 26, 2011 | 08:26 PM
calvette 11
Default balancer
I'm buying a new slp damper
Old Jul 27, 2011 | 05:16 AM
vettenuts's Avatar
vettenuts
SLP is a re-badged Powerbond. The hub should have a keyway milled in it. This is the perfect arrangement to use the ATI pin kit if you want to pin the crank. You should also swap the front seal in the timing cover while you have it off, otherwise you will be back in there later. This can be done without removing the timing cover.
As stated, correct installation should result in no issues. If you used a torque to install then it is not installed correctly. Final bolt load is applied through a 140 degree rotation.
Also, don't use LS1howto for removal/installation. Recipe for disaster.
To help crankshaft
