C5 running hot... Any suggestions?
1/4 mile/AutoX
heat is the worse enemy of the engine, I installed a 180 stat and my tune has the fans come on earlier. always runs about 192, the highest in the last two summers is 206 !!!
Might also check the radiator side saddle tanks and the bottom of the overflow reservoir.
Both are plastic.
In my 01s life, both have developed hairline cracks (with the resultant coolant loss) and had to be replaced
Both are plastic.
What he said. If both fans don't turn on when you turn the AC on, change both the fan motor and the fan relay in the underhood fuse box. As the motors age they start using a lot of current and as a consequence the relays sometimes burn out.
C5 running hot
I have a 98 c5 corvette i just put a new thomo and a new rad on it and it will stay at 210-220 fine just sitting in idle but if i take the rpm's up to 3k for a second it will start to rise in temps then if i drive it it will start to rise to 230 then 240 then so on til i cut it off. I had a tranmissions line leaking some of the trans oil got on the belt i dont know if the belt is slipping or what but i really need help i tryed to burb the system still getting the same thing. i can leave it sitting in the driveway for a hour with no overheating but soon as i start driving it starts to rise water pump has no leaks i have no leaks from the cooling system and i have no signs of head gaskets gone bad someone plz hlep me its finna be spring and i just wanna enjoy the season
Check ur lower hose passenger side mine was luke warm on the right side was burning hot
I think ur going to b waiting awhile for respond. Last comment was 2017 so ill toss how mine ws fix. Did what u did drove me nuts it ended being a bad thermostat. Mr. Gasket 160 was garbage
#33
