Plug Wire Removal
Old Apr 27, 2002 | 12:45 AM
EBSDallas's Avatar
EBSDallas
Default Plug Wire Removal
I'm getting ready to install a set of TR55's and plan on retaining the stock wires for the time being.
I noticed that the wires are on *real* tight. My boot puller can't get a good grip on the plug end boots because of the heat shields.
Is there another way to remove them without yanking on the wires?
Thanks.
Everett
Old Apr 27, 2002 | 02:24 AM
MTWallet's Avatar
MTWallet
Default Re: Plug Wire Removal (EBSDallas)
Definitely don't pull on the wires. With your hand, just grab the boot and shield together and wiggle, twist & pull at the same time and it will pop right off.:cheers:
Old Apr 27, 2002 | 03:27 AM
Crushinator's Avatar
Crushinator
Default Re: Plug Wire Removal (MTWallet)
Some may seem like they're not gonna budge, but keep working them and they'll come. The rear drivers side is a bear! I had to have my wife get that one for me. It's too tight in there.
Old Apr 27, 2002 | 03:44 AM
MDT's Avatar
MDT
Thanks.
Everett
EBSDallas,
I posted the following hint/tip a month or so ago:
Notice that the OEM boots have a hex shape molded into them. As I recall it is 13/16 inches. Whatever size it is....an Oxygen Sensor socket fits it. Slip the socket over the boot....allowing the ignition wire to protrude from the slot on the side of the O2 socket. The socket give you a better grip so you can twist the boot, which is what must be done to break it loose. If necessary you can even attach a rachet and short extension to the socket. My O2 socket also had a hex head on it, allowing for the use of an open end wrench on it.
Unfortunately, in my case, I didn't stumble upon this idea until I was finishing up on the last plug. Used the above method on it and it work like a charm.
Good luck.
Mark
[Modified by MDT, 1:46 AM 4/27/2002]
Old Apr 27, 2002 | 04:17 PM
wwashing's Avatar
wwashing
If I recall correctly you can slide the metal shield back off of the boot. This will allow you to grasp the boot and twist and pull.
Don't forget to apply di-electric silicon gel to the inside of the boots before you put them on your new plugs to keep them from bonding to your new plugs.
Old Apr 27, 2002 | 09:04 PM
rhoeven's Avatar
rhoeven
Twist the boot untill it rotates easily. Then pull and they'll come right off.
Did mine 2 weeks ago. Only the #7 plug is a real pain.
Good luck
Roger
Old Apr 28, 2002 | 10:37 AM
vettenuts's Avatar
vettenuts
Default Re: Plug Wire Removal (rhoeven)
I thought the boots were harder then the plugs to remove, and I removed mine with only 1,000 miles on the car. Definitely twist them first, then they will come off.
Old Apr 28, 2002 | 07:56 PM
EBSDallas's Avatar
EBSDallas
Thanks everyone, I got the plugs installed today. It's been a great weekend because I got my Bassani exhaust system installed yesterday.
I had a perfect score on the old platinum plugs. Eight plugs removed, eight plugs with no pucks! The car has 2,819 miles on it and all of the pucks were missing, what a joke.
The car runs and sounds great at WOT. On to the next mod!!!
Everett
Old Apr 28, 2002 | 09:50 PM
C5XTASY's Avatar
C5XTASY
I believe that not all C5s come with the platimun plugs with pucks. Many have come with a Japanese (?) plug that do not use pucks. I do not remember the name of the Japanese plugs. Perhaps someone else does. That's not saying you didn't actually lose the pucks, but it would be pretty incredible to lose them all in only a few miles, without some pretty serious stuff going on in the engine. :eek:
Ed
Old Apr 28, 2002 | 10:07 PM
C5XTASY's Avatar
C5XTASY
Default Re: Plug Wire Removal (C5XTASY)
Ed
I just did a search on the forum. The information I came up with is that sometime during 2001, GM began using Denso PTJ16R15 plugs in the C5. These plugs do not use pucks. They are supposed to be a pretty good, long-lasting plug. Gapping, I believe was supposed to be .058. Were your plugs the Denso brand?
Ed
[Modified by C5XTASY, 8:26 PM 4/28/2002]
Old Apr 28, 2002 | 10:40 PM
EBSDallas's Avatar
EBSDallas
Just went and looked, they are the Denso plugs.
I feel a whole better not having to worry about the pucks floating around in the engine.
Everett
Old Apr 29, 2002 | 02:00 AM
davidmax's Avatar
davidmax
EBS Dallas enjoy that Bassani we sell alot of them and for a great reson we believe it to be the best system on the market.Call us when your ready for some long tube headers and speak with Nate its right up hi alley.Enjoy Dave S.
To Plug Wire Removal
