2004 Coupe TPMS will not go in relearn mode
Following the relearn procedure the horn never chirps!
Has had a "Service TPMS" message on the display for several months.
I was at the tire store and asked them to relearn the system after plugging a tire.
The TPMS system will not go into learn mode. Tech said his equipment could interrogate all 4 sensors so I would assume the sensors are still OK.
OK, what are the trouble shooting steps and where is the module in the car?
Thanks!
Thanks!
Sensors were working before a turn signal bulb was replaced.
The fact that you can see "TPMS relearn" in the DIC implies that the RFA is being seen by the BCM. Furthermore if your key fobs are working (they are working, right?) the RFA is receiving a signal and passing it to the BCM which rules out cabling issues (power and OBD serial bus). There is only one receiver in the RFA which listens to both TPMS and key fobs on the same frequency.
Did you try disconnecting the battery terminal for 10 mins, then reconnect and retry?
First thought. I had trouble getting my RFA to receive TPMS messages when the OBD bus was "busy" with several other messages. These messages were generated by the toneau cover and doors being open, but mostly by a trickle charger on my battery. You might try the normal sync again having all those conditions addressed.
I also agree with 8VETTE7, a good strong magnet on the barrel of the tire just behind the stem for 5 seconds should trigger the horn. If the tire tech queried your TPMS with his TPMS tool and your DIC was in learn mode, the horn should have chirped and moved to the next tire. If he was just querying without the DIC ready, the RFA would just ignore it.
Todd
8VETTE7 provided good advice .....post your codes.
Same problem as jaa1992
2013-I am having this same problem with a 2000 Vette. I replaced all the batteries in the sensors, but the TIRE TRAINING mode won't switch over to TIRE LEARNING after pressing RESET.
When the batteries were dead, the DIC would continuously revert back to SERVICE TPMS while driving. Now that the batteries are good, the DIC doesn't revert anymore. BUT, when I start the car anew, then the SERVICE TPMS message returns until I reset it. The tire data is all blank, by the way.
Like the originator of this thread, the system won't go into relearn mode. What was the resolution of JAA1992's problem? Sounds like his was identical to mine.
UPDATE "no RFA Comm"
I have an update, but still no solution. I pulled the DTC codes from the Driver's Info Center. They are:
1176H
2282H
1064H
2283H
2285H
BO-No RFA Comm
OK, the RFA Comm is the Remote Function Actuation receiver/computer. So this fault could be why the car won't go into TIRE TRAINING mode. But my remote key FOBS all work!!!! Are these different receivers that the RFA receiver? I didn't think so.
1176H
2282H
1064H
2283H
2285H
BO-No RFA Comm
Yes. The receiver simply reads transmissions from the transmitter(s), decodes the transmission and forwards it to the BCM, PCM and IPC. So if it works for the door remotes, it is alive and well.
Is the floor in the passenger foot well wet??? If so the problem is likely in the BCM.
So, here's the update. I did the full battery replacement, as I mentioned, myself. The DIC stopped giving me repeated warnings, but just a warning on startup. So, something changed.
I located the Remote Function Sensor module, above the left rear wheel, inside the car. I unplugged and replugged it several times. Started the car, and immediately got all 4 tires pressure info flawlessly. I can only assume I somehow reset it, or restored an oxidized connection. It all works now.
FOR THOSE OF YOU WHO ASSUME IF YOUR KEYFOB IS WORKING, THE RSA IS TOO, THAT IS WRONG. My remote key has worked fine all through this ordeal.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The door control modules have nothing to do with the FOB or Tire Pressure sensors. (TPS)
The REMOTE FUNCTION ACTUATOR (RFA) module (located in the rear near the drivers side rear speaker communicates with the FOBs and TPS/s The RFA transmits the data to the BCM and the BCM uses that data to display tire pressure data and FOB actions. The BCM actually operates the locks, the lights and trunk latch and all the remote functions.
I agree.. If you have FOB Function, the RFA is working. The newer C6 cars need a TPS interrogator to program the TPS. As far as I know, that will not work on a C5 TPS. We use a magnet where as the magnet will NOT work on a C6
