Jacking Height to Remove OEM Mufflers?
Old Jul 29, 2011 | 09:41 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Default Jacking Height to Remove OEM Mufflers?
My Corsas are here. The instructions say that to get the car high enough to take out the stock mufflers it should go to a shop with a lift. Somebody here has done it without a lift, right? Did anyone take note of how high the car needed to be off the ground? Will a decent hydraulic jack get it up there? I just thought I'd ask before wasting my time. Any advice is appreciated. (Don't be fooled by the avatar; I'm talking about an 03 vert.)
Old Jul 29, 2011 | 09:47 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
If you are cutting off the old exhaust with a sawsall you only need a couple of feet.. but if you want to get them off without cutting you need atleast three feet...the stock pipes are welded and you can not get them over the rear cradle without having at least three feet of clearance.
ON a side note, you might as well cut them off because the old exhaust is worthless. You can't even give them away..
Old Jul 29, 2011 | 10:08 PM
Dream C5's Avatar
Dream C5
This will give you a pretty good idea, beware it aint for the faint of heart!
Old Jul 30, 2011 | 02:08 AM
1FUNC5's Avatar
1FUNC5
Do not try this at home!!!!!!!!! The car can and will roll off the jack! Too much angle!
Old Jul 30, 2011 | 02:36 AM
soggysailor's Avatar
soggysailor
You can do it...........
Kinda like this
Old Jul 30, 2011 | 07:10 AM
Rich Silvestris
St. Jude Donor '05
Thanks, guys. Great responses. I get it!
Off to the shop it goes. I wanna live!!
Old Jul 30, 2011 | 07:51 AM
guido7834's Avatar
guido7834
On grass, no less!
Old Jul 30, 2011 | 08:41 AM
Rickster1's Avatar
Rickster1
From: Longmont on the Front Range of Colorful Colorado
YIKES, I just had a locally owned muffler shop do the switch from Borla Stingers to Z06 ti's. Took him less than an hour (and he was talking to several people while doing it) and he charged $60. Money well spent.
Old Jul 30, 2011 | 08:48 AM
RaW Z06's Avatar
RaW Z06
Wise choice! It's relatively cheap to have a muffler shop do the install.
Without having the proper lift at home, the job can be highly dangerous.
Old Jul 30, 2011 | 09:24 AM
Lucky Penguin's Avatar
Lucky Penguin
Navigator
Default muffler removal
Hi, I had mine jacked up crazy high with wooden blocks etc and could not get them off. I always thought backing up on a truck loading dock would of done the trick, just don't go too far! I ended up cutting them off with a nice chain exhaust pipe cutter in case I ever wanted to sleeve them back together. I ended up throwing them away when we sold our house and moved. Good luck.
Old Jul 30, 2011 | 10:04 AM
johnson-rod's Avatar
johnson-rod
You do have to pick the car up quite high. With some ingenuity it can be done safely. I used a combination of jacks, stands, ramps, wood and wheels under the car. It was high and it was safe. Once you get them over the axle you can let the car down to a more reasonable level for tightening and lining up.
To Jacking Height to Remove OEM Mufflers?
