clutch fluid
Old Aug 1, 2011 | 03:55 PM
BigRobDsp's Avatar
BigRobDsp
Default clutch fluid
My clutch fluid is black and I plan on changing it using the Ranger method tonight. I read about 20 articles that suggested Prestone DOT 4 synthetic as a good replacement. Then I read one article that warned against using DOT 4 synthetic in a C5 that was calibrated for DOT 3. Advice please???
Old Aug 1, 2011 | 04:28 PM
dougbfresh's Avatar
dougbfresh
Use Dot 3
Old Aug 1, 2011 | 05:10 PM
lucky131969's Avatar
lucky131969
Originally Posted by dougbfresh
Use Dot 3
Dot 3?? That's what the owners manual recommends......why would you want to use that?
Old Aug 1, 2011 | 05:16 PM
Dennis Wilson's Avatar
Dennis Wilson
DOT 4 is OK.
Old Aug 1, 2011 | 05:32 PM
baxsom's Avatar
baxsom
Dot 4 is backwards compatible with DOT 3 with a higher boiling point from everything I have read. it is the DOT 5 that you have to be careful with.
To clutch fluid
