Engine Block Digitizing at TSP!
Old Aug 3, 2011 | 06:46 PM
JohnJ@Texas-Speed's Avatar
JohnJ@Texas-Speed
Premium Supporting Vendor
Default Engine Block Digitizing at TSP!
Here is a movie we recently made of our new Centroid B4250 4-Axis CNC machine. This is the first part of our machining process where we use the machine to locate where the block is at, and what we need to do to get the motor back to blueprint specs. We sped the video up a little(4x) to get through a bit quicker.
http://www.youtube.com/watch?v=RIa0StHVYQs
Old Aug 3, 2011 | 07:06 PM
Pumba's Avatar
Pumba
John,
I would like to suggest that you mount the engine via its engine mounting points and the bellhousing attaching surface, rather than using a bar through the main bearings.
NASCAR engine builders find enough bending of the block when mounted as I state above to change the centerline of the crankshaft, the cam bores, and the cylinder's roundness.
Old Aug 4, 2011 | 10:17 AM
JohnJ@Texas-Speed
If you look a little closer you will see the engine is mounted by the mounting points and bellhousing surface, we use the bar through the mains to center the block.
Old Aug 4, 2011 | 11:16 AM
LoneStarFRC's Avatar
LoneStarFRC
Nice!!
Matt told me recently how you guys have now brought all your machine/assembly work in-house on your engines and have a bunch of new equipment and some new folks to get the work done.
Is this digitizing part of the procedure on all your engine builds? I'm thinking LS7 441......hmmm.
Old Aug 4, 2011 | 11:17 AM
Pumba's Avatar
Pumba
John,
I am sorry, but the video that I viewed did not have the engine mounted using the ENGINE MOUNT pads.
Old Aug 5, 2011 | 10:48 AM
JohnJ@Texas-Speed
Originally Posted by Pumba
John,
Sir,
The engine is mounted in 11 different points in that machine. Maybe the video provides a bad view, but I assure you this is being done correctly!
Old Aug 5, 2011 | 10:51 AM
JohnJ@Texas-Speed
Originally Posted by LoneStarFRC
Nice!!
Yes sir we digitize every block to make sure everything is correct in the motor. This is part of the process that has to be done before the motor can be shipped. You would be amazed at how many brand new GM blocks have to be fixed in order for the motors to be "right."
Old Aug 5, 2011 | 10:56 AM
Jason 98 TA's Avatar
Jason 98 TA
I want to clear something up real quick because I think your not looking at it correctly. The crankshaft & camshaft bar are not there for mounting, they are used to perfectly locate the block in a manor that allows us to put the camshaft & crankshaft directly in line. This is a common problem in production blocks, the factory does not typically put the cam & cranks in alignment. By using this machine we can digitize the camshaft & crankshaft centerlines & locate them perfectly in line. The block is actually mounted off dowels & bolts on the back of the block. The camshaft & crankshaft bars will actually spin freely in the block while it's mounted in this fixture. One of the steps we take when mounting the motor in the machine is spin the bars to make sure the block isn't binding up.
Compare this to any LS shop in the entire world. I bet nobody does anything anywhere near the level of detail that we put into our short-blocks.
John,
Old Aug 5, 2011 | 01:03 PM
LoneStarFRC
Impressive level of quality control. Thanks.
Old Aug 5, 2011 | 01:20 PM
Pumba's Avatar
Pumba
Jason,
I applaud your efforts to make improvements in the measuring and machining of engine blocks.
What my original comments was meant to do was to stimulate your thinking:
- NASCAR engine builders have learned that the crank and camshaft centerline and roundness are significantly effected by how their machining centers mount the block as it is being measured and machined.
- The most advanced shops measure and machine the block while it is mounted by the same fastener holes as it is mounted in their cars.
- They have also learned to Line Bore the blocks while they are mounted in car-position, using only the engine mount pads and the rear face of block while the block is in car position.
- They bolt the cylinder heads to the block, using a head gasket, while they Line Bore.
- They attach any main cap mounted oil pump housing to the main cap while they Line Bore.
- Finish Honing is done with the block heated using hot oil to 190 degrees F.
I hope some of this adds to making your machining facility even more accurate.
Old Aug 9, 2011 | 08:35 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Jason,
What level of misalignment are you finding? What tolerance of alignment do you hold? How many blocks have you worked on with this issue?
Old Aug 12, 2011 | 08:19 AM
Eric D's Avatar
Eric D
A comment like “factory does not typically put the cam & cranks in alignment” needs to be quantified. Compared to what? To what tolerance do you hold cam to crankshaft alignment on the blocks your company works on? How much better is this than production?
Old Sep 23, 2011 | 02:55 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Am i the only one who stops reading a post as soon as i see the word NASCAR show up?
Old Sep 23, 2011 | 07:26 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Doesn't look that way. You didn't get in until post #13......of a 6 week old topic!
To Engine Block Digitizing at TSP!
