Traction control and abs light
Old Aug 3, 2011 | 09:09 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Default Traction control and abs light
What can a 2004 with 9k cause the traction control and abs light come on. Thanks for any info.
Old Aug 3, 2011 | 09:14 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Pull your codes and post up. Hold Options and press Fuel 4 times. Codes will flash up on the DIC.
Old Aug 3, 2011 | 09:28 PM
coia96vette's Avatar
coia96vette
If you get C1287/C1288 code, that means the swps is going out. Just had to replace mine on my 2004 coupe. Seams to be a common problem on 04's.
Old Aug 3, 2011 | 10:03 PM
CamminC5's Avatar
CamminC5
I don't think 1277/1288 would set off the ABS light. Probably an EBCM issue.
Old Aug 4, 2011 | 08:16 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Thanks for the info. Maybe rare the drivers front abs sensor. Thanks philly joe
Old Aug 4, 2011 | 11:00 PM
BigGun's Avatar
BigGun
It is not what you would call a rare problem, search the code. Check the connector coming out of the hub first. You may get lucky and it is just disconnected or the wire pulled loose.
Old Aug 5, 2011 | 01:52 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Check this site. Very well done. Philly joe
Old Aug 5, 2011 | 07:46 AM
AU N EGL's Avatar
AU N EGL
a few 2004 had a YAW sensor problem.
the YAW sensor sensor the passenger seat next to the tunnel
Needs to be replaced by dealer
Old Aug 5, 2011 | 09:38 AM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by CamminC5
Pull your codes and post up. Hold Options and press Fuel 3 times. Codes will flash up on the DIC.
Isn't it four times?
Old Aug 5, 2011 | 09:43 AM
lucky131969's Avatar
lucky131969
Yep....always has been.
Old Aug 5, 2011 | 11:58 AM
CamminC5's Avatar
CamminC5
Thanks for the correction.
Old Aug 5, 2011 | 12:20 PM
CSM Z06's Avatar
CSM Z06
You can get these from a voltage issue. I have a 03 that I have on a battery tender and I drive a couple times a month. I use to get traction control and abs light whenever I first took car out. After I drove for a bit, shut off car, restarted and I wouldn't have the traction and abs lights. I was adviced that it could be a voltage issue and to try direct wiring of the battery tender before I try more expensive options. I direct wired the battery tender and sure enough have not had the issue since and it has been over a year.
To Traction control and abs light
