how much oil pressure with high-flow pump?
Old Aug 7, 2011 | 10:07 PM
redrckt97's Avatar
redrckt97
Default how much oil pressure with high-flow pump?
I recently had a new cam installed along with an LS2 timing chain and a high-flow oil pump - the oil pressure (guage and DIC) seems to be about the same as it was with the stock pump - should it be higher?
Old Aug 7, 2011 | 10:37 PM
Paul 75 L82's Avatar
Paul 75 L82
I used the Texas Speed ported LS6 pump, I run about 55 lbs at 40-50 mph. 80 lbs before everything warms up.
Old Aug 7, 2011 | 10:40 PM
mchicia1's Avatar
mchicia1
High flow pump != high pressure pump. The only thing that can raise your pressure is changing the relief valve spring. If the stock relief valve spring was left in, then you will have stock pressure. It is a common misconception that higher oil pressure means better protection. This is completely false unless your motor was designed like this from the get go. Too high pressure can actually hurt your motor...by pumping too much oil to the top of the motor at WOT.
Since you still sound like you have a stock block, you made the right choice (by accident) sticking with the stock relief valve spring. As long as your pressure is still where it was before, you are in a good shape.
Old Aug 7, 2011 | 11:51 PM
Xtreme Z06's Avatar
Xtreme Z06
Old Aug 8, 2011 | 07:04 AM
ZZ06's Avatar
ZZ06
man that seems high. curious are you using a 160* T-stat? I replaced my LS6 with a....LS6!!
Old Aug 8, 2011 | 09:13 AM
redrckt97's Avatar
redrckt97
thanks for the info!
Old Aug 8, 2011 | 04:41 PM
zavod's Avatar
zavod
Mine runs about 80psi at idle and pretty much 100 psi the rest of the time unless the oil temps get around 245 F then I see 60psi....
I have a pretty big cam with High Vol, High Pres Oil pump!
Old Aug 8, 2011 | 07:54 PM
vsocks1's Avatar
vsocks1
That seems like way too much pressure
Old Aug 8, 2011 | 08:40 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Good Lord!!! all your oil is in the top of the engine!
Old Aug 8, 2011 | 10:21 PM
zavod's Avatar
zavod
Its been that way since I had England Green here in Houston do one of there kitchen sink cam installs. I talked to them about it and they told me not to worry. Hopefully this was done correctly and will hold together!
Old Aug 9, 2011 | 06:01 AM
ZZ06's Avatar
ZZ06
To how much oil pressure with high-flow pump?
