Transmission / TT Install Procedure
The last time, I installed the TT and the tunnel plate and then let the tunnel plate hold-up the back of the TT while installing the transmission and differential. The trans is easy to push into place under the car and the trans bolts are easy to get to while under the car. A long extension and flex joint lets you reach around the diff and trans to the bolts with lots of room to spare.
If it's all apart you have to bolt it together at some point, so it's really not much more work bolting it together under the car instead of on the floor. I usually do this stuff myself and the whole assembly is a fair bit of weight to balance on a floor jack and it's awkward to move around as well. The trans and diff sit decently on my floor jack and I can then move it around wherever I need it and steer it around the jack stands holding the car up. That would not be possible with the torque tube hanging off the front of the trans and I'd have to drag it under the car before putting it on the jack.
Peter
Peter
Thanks for the replies!
