STOP LEAK is formulated to plug pin holes and small leaks in a LIQUID SYSTEM that contains a water based fluid.
Your rear-end is leaking because of a worn seal, excessively worn hard parts or damaged gaskets. The rear contains a viscous lubricant that protects sliding surfaces (faces of the gears and ball bearings). Adding the SOLID particles in stop leak to a mechanical rear-end would contaminate and interfere with the lubricating properties of the 90 weight. You think you have problems now,, adding that stuff, you may need a NEW REAR!
The OLD TIMER procedure of adding saw dust and or bananas to the rear-end to QUITE it down would fall into the same category!
PLEASE DONT DO IT! My guess is you have a PINION SEAL leak. Just find the correct procedure and replace the seal.
Members in the correct generation sub-forum might have some suggestions for you (main menu page).
You could check the websites for LUCAS OIL or JUSTICE BROTHERS for products. If it were me, I'd use such a product only as a temporary measure until the correct repair can be made.
thank you, it leak a couple drops a day. i think it is link from the middle seal that connects to driveshaft. do you know if I can replace that seal with removing the entire gearbox?
