Investigating Drivetrain Noise
Old Aug 10, 2011 | 11:55 AM
sgancarz's Avatar
sgancarz
Default Investigating Drivetrain Noise
Does anyone know if there are any issues with running the vehicle up to speed without having the wheels on the ground? I am trying to determine the cause of a high pitched whine coming from the drivetrain. I just want to make sure I am not going to cause any other damage by running the vehicle while on the lift.
Old Aug 10, 2011 | 12:04 PM
cdkcorvette7's Avatar
cdkcorvette7
What kind of lift?
Old Aug 10, 2011 | 12:16 PM
sgancarz's Avatar
sgancarz
Standard two post body lift.
Old Aug 10, 2011 | 12:58 PM
cdkcorvette7
I've never done this, but I can't really imagine it hurting anything on the car... I mean I wouldn't go WOT or anything but I can't think of anything mechanical that would be damaged...
BUT
The car will lurch when you step on the gas even with the wheels off the ground and I'm not sure I'd want my car rocking back and forth on a lift... especially if I was under it looking at the drivetrain
What kind of noise are you investigating?
Old Aug 10, 2011 | 01:50 PM
sgancarz's Avatar
sgancarz
I've got a high pitched whine that begins @ about 45mph and intensifies up to about 75mph, at which point it is quite loud. Just need to see where the noise is originating.
Old Aug 10, 2011 | 02:10 PM
corvettebob1's Avatar
corvettebob1
You won't be able to tell anything by doing this the drivetrain must be loaded to find any whine.
If you have and A4 99% of the time it will be the axle if you have a manual 99% of the time it will be the axle.
Does the whine change between drive and coast?
Old Aug 10, 2011 | 02:41 PM
cdkcorvette7
What year, how many miles, which trans? Any mods? Any recent work done?
Old Aug 10, 2011 | 04:42 PM
sgancarz's Avatar
sgancarz
2000 FRC MN6 w/17000mi Mods include HCI, Calaway B/B TB, Vararam, Long Tube Tri-Y headers, Corsa Exhaust, Cartek Clutch, DTE Stage II Diff (w/hardened output shaft, 4.10, cradle). Last work done was new RSD Snap Shifter (done just prior to my purchasing).
Whine is not present when coasting.
Old Aug 10, 2011 | 07:09 PM
Cybermind's Avatar
Cybermind
You also need to keep in mind that the geometry of the axle shafts will be altered while on a lift since the suspension is hanging. It is not a good idea to go full speed in this state. It will probably put some strain on the cv joints and you probably notice some vibration. If you still plan on doing it, don't forget to completely turn off the traction control or it will activate.
Old Aug 11, 2011 | 12:35 PM
corvettebob1
"Whine is not present when coasting"
You have an axle whine more then likely pinion bearings have failed or it wasn't set up properly.
Old Aug 12, 2011 | 09:20 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Use a pair of jack stands and support the lower control arms. Have the TC off and get it up to speed where the noise is. If I had to guess, it would be the ring and pinion gears. Let us know if/when you find out what the noise is.
__________________
Old Aug 18, 2011 | 04:23 PM
sgancarz's Avatar
sgancarz
Rick,
Thanks for the tip. Unfortunately that is my thought as well. I certainly don't like it though. Especially being the Diff only has 5,000 miles on it.
Old Aug 18, 2011 | 07:15 PM
shadowman1's Avatar
shadowman1
Old Aug 18, 2011 | 07:55 PM
cptinjak's Avatar
cptinjak
Does it make noise in gear, while decelerating ("engine braking") or ONLY upon acceleration? Is the noise present only accelerating from45-75 or does it continue above 75?
Is the transmission stock?
Old Aug 18, 2011 | 08:08 PM
Chris Stewart's Avatar
Chris Stewart
I've done this many times, I call it the jackstand dyno. No it won't hurt anything, and yes it's useful to find the source of problems.
Old Aug 18, 2011 | 11:00 PM
sgancarz's Avatar
sgancarz
No noise when decelerating. Whine is most noticable at a constant speed. Whine is not as noticeable once over 75.
Old Aug 18, 2011 | 11:19 PM
cptinjak's Avatar
cptinjak
Man, that could be a few things. Really tough to say.
Be very careful diagnosing based on noise alone. Driveline sounds have a tendency to resonate through the torque tube. I just did a trans rebuild in a car that had the trans done a year ago. The mainshaft had been over-shimmed and the input/cluster were eating each other. You would have bet money the noise was in the bellhousing.
Good luck. Be sure to let us know what you find.
Old Aug 19, 2011 | 06:18 PM
Chris Stewart
Your description is similar to my problem with gear whine. A local shop rebuilt my diff, and a few months later it developed problems. Always a specific 50-60MPH range, it started as a ringing sound, and evolved into a gear whine. I believe it was due to improper setup of my ring/pinion. Sound anything like this video? For mine, I pulled the diff and sent to RPM, and it's worked perfectly since they rebuilt it.
To Investigating Drivetrain Noise
