differential fill plug leak
Old Aug 10, 2011 | 12:34 PM
guido7834's Avatar
guido7834
Default differential fill plug leak
small drop of fluid from it so I am replacing the plug and washer. Seem to be having a hard time removing the washer and "limited slip fluid only" tag from the old plug. Also can't seem to get the washer off the new plug easily either. So my question is, can I just install the new plug without the tag? I don't want to bugger up anything trying to remove them.
Old Aug 10, 2011 | 01:23 PM
cdkcorvette7's Avatar
cdkcorvette7
Hmmmmm... I just replaced my gear oil recently and I don't remember having a "tag" there at all... And why are you trying to take the washer off the new bolt?
Here's the procedure I used:
http://forums.corvetteforum.com/1570951622-post2.html
Old Aug 10, 2011 | 01:34 PM
guido7834's Avatar
guido7834
I was trying to remove the washer so I could put the tag between the bolt head and washer. I guess it's going on without the metal tag.
Old Aug 10, 2011 | 03:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I think the tag goes on the FILL PLUG!!!!! NOT the drain plug!!
Old Aug 10, 2011 | 03:13 PM
guido7834's Avatar
guido7834
That is exactly what I am talking about. I had the leak at the FILL plug.
Old Aug 10, 2011 | 03:28 PM
lucky131969's Avatar
lucky131969
I'm surprised that you would get a leak from the fill plug.......unless....it was over serviced.
Old Aug 10, 2011 | 03:29 PM
cdkcorvette7
A vice, a small flathead screwdriver and a pair of pliers is the easiest way to remove a crush washer if you feel like you have to. Personally I'd just leave it off but that's JMHO...
Old Aug 10, 2011 | 03:42 PM
guido7834's Avatar
guido7834
I think the washer was bad.
guido7834's Avatar
guido7834
Old Aug 10, 2011 | 05:54 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Is it a SEMS ( captivated washer), or is it a loose washer? If it is not a SEMS (designed to stay in place as an assembly and not to be removed) then by all means go ahead and add the tag....which is shown in DeeGee's link sketch.
http://www.caparoatlasfastenings.com...ew.asp?pid=357
Your forum's self-appointed fastener engineer from the Motor City...
Old Aug 10, 2011 | 06:44 PM
Cybermind's Avatar
Cybermind
A little dab of high temp gasket sealant on the threads should stop the leak. I use it all the time just to be sure.
Old Aug 11, 2011 | 06:55 AM
Jewjenk's Avatar
Jewjenk
Hmmmmmm, just changed mine, did not see a washer and put the tag back on. No leak............
To differential fill plug leak
