Car won't start
Old Aug 10, 2011 | 09:14 PM
C5nNC's Avatar
C5nNC
Default Car won't start
2002 Z06 12,000 miles. Running fine month and half ago when parked. left with 1/8 tank gas. Cranked a little slow this morning and pulled out of garage into hill of driveway to warm up before driving. Backed on out of driveway and it died on me. Would not crank back. will start and just barely idle for 20 seconds and then dies. If I touch throttle immediately dies. Put 2 gallons of fresh gas in and charged battery. Had one message say "low voltage" but no other codes. After full charge on battery, car still does same thing. Disconnected battery for 10 minutes in case of a ECU issue. Wiped out throttle body. Still same results. HELP!
Old Aug 11, 2011 | 09:53 AM
mmartinez's Avatar
mmartinez
I would take battery and have it load tested, you may have a low voltage condition that C5's will not run if battery voltage drops to low, Good Luck.
Old Aug 11, 2011 | 12:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remove the battery,,,charge it and go have it tested. Reinstall,,, clear the DTCs,, and re start. If you have issues,, READ AND POST THE DTC's
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
You can read the DTCs while the engine is running. If you turn the engine OFF and then back ON, that can clear some DTCs that may be important with identifying a problem. One example is a Misfire DTC (p-0300) If the engine is shut down, the DTC will clear.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Aug 13, 2011 | 08:58 AM
C5nNC's Avatar
C5nNC
Default Updates
Ok, took alternator and battery in. Both good, but bought new battery to be sure. No luck.
One important thing I noticed. With all C5s, when you turn the ignition on before cranking, you always here a series of clicks kind of like priming for a couple of seconds. When I turn my key on, it is silent.
At this point, it only turns over and will not crank and idle. Here are the codes I had: (All codes were H)
40 - BCM B0432
60 - IPC U1040
60 - IPC U1176
A0 - IDCM B2282
A0 - IDCM B2284
A0 - IDCM U1064
A1 - RDCM B2283
A1 - RDCM B2285
A1 - RDCM U1064
Old Aug 13, 2011 | 08:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You either have a ground issue OR you have a fuel pump issue. Either way,, if you don't hear the fuel pump prime,,,, examine chassis ground G-401 or the fuel pump components:
Check under hood mini fuse #13 and relay #35. Power for the fuel pump is switched thru the IGNITION SWITCH. Make sure you have power at the fuse when the ignition is ON.
BC
Old Aug 14, 2011 | 11:30 PM
C5nNC's Avatar
C5nNC
Default Fixed!
The relay and fuse were fine. I removed chassis ground 401 and cleaned it and then the ground wire that mounts on a pump just above the transmission as well. One or the other fixed the priming and it cranked right up. Will test drive tomorrow to make sure, but should be good to go!
To Car won't start
