Cooling Fan Sensor Replacement ??
Old Aug 11, 2011 | 02:34 PM
PHASTC5's Avatar
PHASTC5
Default Cooling Fan Sensor Replacement ??
I recieved great feed back on my last post regarding a cooling fan temperature setting of 226 degrees with the AC in off posistion. Since I live in "FAR" Northern Calif. and ambient temps do get very high, I want to know if any of you have gone to a lower sensor set to maybe 200-210 degree? I have been offered a 180 degree thermostat but fail to see it helping me if the fan doesn't come on until 226.
Any any help !!
Old Aug 11, 2011 | 03:49 PM
cdkcorvette7's Avatar
cdkcorvette7
Any any help !!
Buy a 160 degree thermostat and get your car tuned so your fans come on at lower temps. You can buy a handheld tuner like the diablo predator and do it yourself (very easy) or find a tuning shop or someone with HP Tuners or EFI live to do it for you...
Old Aug 11, 2011 | 05:03 PM
TOPCATHR's Avatar
TOPCATHR
I installed a derale fan control kit. The probe goes in the radiator hose. It works great, my car never gets over 210
even with the ac on. You can set it at any temp you want. I spent 26.00 and its only a couple of wires.
Old Aug 11, 2011 | 05:43 PM
PHASTC5's Avatar
PHASTC5
Thanks for help. I am afraid to go down to a 160 thermostat due to the lovely State of California and the SMOG laws that come with it. I will go to the 180 thermostat, and go get the fans re-programed to come on at 210. I didn't know that was possible,and figured I would be replacing a sensor.
Thanks for the insight !!
Old Aug 11, 2011 | 06:45 PM
KevinZ06's Avatar
KevinZ06
Does anyone have a link for this kit?
Old Aug 11, 2011 | 09:03 PM
cdkcorvette7
Think you'd probably be fine with a 160 but 180 will work too... Get the first fan temp programmed to come on around 194 and the second one to come on around 200
Old Aug 12, 2011 | 07:16 AM
TOPCATHR's Avatar
TOPCATHR
Kevin, i got it from jeggs on line but i understand pep boys also sells the kit.
If you install it the wires to the fans are light blue under the engine compartment fuse panel. Lift the top ,the wires are on the drivers side of the box .
Old Aug 12, 2011 | 09:32 AM
dougbfresh's Avatar
dougbfresh
Why do you need to do ANYTHING here?
Old Aug 12, 2011 | 05:15 PM
PHASTC5's Avatar
PHASTC5
I live in an area where 115 - 120 degrees is not uncommon. I hate to see any engine waiting for the cooling fan to come on at 226 degrees. Maybe I'm just allittle "old school" due to having worked on serveral engines over the years that burned up, or spun bearings.
I hate to drive in worry over a high temp gage.
Old Aug 17, 2011 | 09:56 PM
KevinZ06's Avatar
KevinZ06
Thanks, I'll check it out.
Old Aug 18, 2011 | 05:16 AM
vettenuts's Avatar
vettenuts
Note that you can modify the stock thermostat to open at any temperature you want for under $1, why buy a new one.
Old Aug 18, 2011 | 12:13 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
SacCityCorvette has the Cool It, a simple plug and play unit that allows you to turn your high speed fan on when ever you need it with the use of a wireless FOB.
http://www.saccitycorvette.com/COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
To Cooling Fan Sensor Replacement ??
