LS7 swap or Supercharger?
Old Aug 11, 2011 | 03:31 PM
SDLS1Rider's Avatar
SDLS1Rider
Default LS7 swap or Supercharger?
I would like to see some opinions from people who frequent this section.
I have a 04 C5 coupe that currently has a H/C making 438 rwhp/378 rwtq. Suspension mods are in sig. The car was done right by Excelsior Motorsports, a perfectionist who took his time. The car runs great and I have had no problems. I love the ride. This car is set-up the way I like it and I'd like to keep it.
Now, lets just say this set-up is too hot for the street. I may have to make some adjustments but I'm addicted to the performance. This would have to be a smog legal application.
I've been thinking of two directions to take. A supercharger kit, probably A&A, or an LS7 swap (probably goto RPM Motors, and it has to be a crate LS7). For the purposes of this thread I'm not looking at a built stroker. The supercharger option is cheaper and will ultimately generate more HP. The LS7 option will nearly double the cost, but be reliable and provide great low end torque. S/C is technically a bolt on, while the LS7 is a major modification.
So what are the some real world pros and cons. I do mainly canyon carving. Could a S/C give the lower rpm performance of an LS7? Assume cost is not a prohibitive issue.
Old Aug 11, 2011 | 07:10 PM
tiojames's Avatar
tiojames
I had the same choices and went with Andy's supercharger set up. Drive train is mostly stock so he kept the RWHP to a little over 580 and said when and if I beefed up the drive train there was plenty left. Car is easy to drive, gets mid to low 20's on fuel mileage and has a fair amount of HP. His kit has a C.A.R.B. sticker and if your cam isn't too radical car should pass smog.
Old Aug 11, 2011 | 08:01 PM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
If $ isn't the issue, I would take the LS7. Bone stock performance, good MPG and reliability! ...not to mention the awe factor
Old Aug 11, 2011 | 09:36 PM
cdkcorvette7's Avatar
cdkcorvette7
If money isn't an issue... Both
Old Aug 11, 2011 | 09:59 PM
SDLS1Rider's Avatar
SDLS1Rider
If it's both then money becomes a big issue!
Old Aug 11, 2011 | 10:20 PM
thetaxman's Avatar
thetaxman
Ls9
Old Aug 11, 2011 | 10:22 PM
Joe_Planet's Avatar
Joe_Planet
sc will be much cheaper and better imho, with the ls7 you'll also have to do a drysump, so think more like 3x cost
Old Aug 11, 2011 | 10:28 PM
ZZ06's Avatar
ZZ06
Yea your looking at BIG money to do an LS7 swap.
Old Aug 11, 2011 | 10:30 PM
lucky131969's Avatar
lucky131969
.....conversion kits are available for the LS7 .....dry to wet sump.
Old Aug 12, 2011 | 12:46 AM
SDLS1Rider's Avatar
SDLS1Rider
How will a dry sump make it 3x the cost?
http://forums.corvetteforum.com/c5-t...-complete.html
Old Aug 12, 2011 | 10:01 AM
cdkcorvette7
If it were me I'd probably go with the supercharger since it'll make similar power at a fraction of the cost and make it significantly easier to revert back to stock if I ever needed/wanted to. Then I'd put the rest of the money I'd have spent on the LS7 into some other things (custom D-Bottom Steering Wheel, nicer seats, audio, wheels etc.) or possibly something non-vette related that you want...
The thing is, an FI car is going to have very different performance characteristics than an NA car. How are you planning on driving it? Strip, track, street only? I think you should probably find an FI corvette to drive (surely someone in a corvette club near you has one) then find a C6Z06 to test drive and see which one you like better.
If you do the build right the first time, and it kinda sounds like you're going to, I'm not sure I'd be more concerned about the reliability of one setup over another...
JMHO. Either way you're going to have a badazz vette. GL
Old Aug 12, 2011 | 10:39 AM
SDLS1Rider's Avatar
SDLS1Rider
Spirited canyon carving.
To LS7 swap or Supercharger?
