C5 Front Caliper in Rear
#202
Chris
#203
#205
When I put to together years ago the stock lines appeared to be too close for comfort and since I was changing everything replacing lines just made sense to make sure there was enough clearance. Stock lines may work I just don't know.
#207
I just did this mod. C6Z51 front brackets milled down 6mm, C6Z51 rear rotors, stainless line kit made by Doug Rippie Motorsports (top notch lines) and DTC70 pads. I put C6Z calipers in the front with DTC60 pads and makes for an epic stopping combo. Going to laser some stainless pad shims when pads get low to take up the thinner rear rotor.
lrbinwpb (11-14-2021)
