I know a guy that road races like that. He had to change the bias spring, which means the antilocks no longer work. I'll see if I can contact him and get the lowdown.
It sure looks better! However, there are engineering reasons why the rears are smaller...could really upset the hard braking results.
I'm wondering about this too... Would increasing the stopping power of the rears without doing anything to the fronts have a negative impact? Seems like it might...
When people install big brake kits they significantly increase the stopping power of the front AND rear brakes. Not sure if it's a good idea to do it this way.
This is why a brake proportioning valve may be necessary.
To do this would be cheaper than a big brake kit and you would achieve a similar look.
It can be done but several changes are required for the swap to function.
1) Correctly sized caliper bracket required to move caliper farther out from hub based on your rotor size selection.
2) The dual piston front caliper has a much larger piston volume than the single piston rear. To keep everything even close to properly functioning, you will need a new bias spring and most likely a proportioning valve. Electronics WILL NOT adjust for this differential.
Too much rear bias and they will lock up every time a hard stop is tried.
3) Due to fluid flow volume changes your ABS will be "iffy" at best. Flow volumes are engineered into the system based on stock caliper sizing.
If you are going for car show "bling" with this setup and do not drive the car agressively or often, you will probably be fine. If you are going for track performance - forget it. The required proportioning to keep the rears from locking up will negate any benefit potentially offered by the bigger caliper and rotor. You will be much better off spending the $ on a properly designed and performing front and rear system from Stoptek, Wilwood or other vendor.
I've been watching this thread and am reluctant to join in but here it goes for the benefit of those interested in doing this mod...
I have C5 front calipers with C6 Z51 rear rotors on my car... I retain the factory parking brake, there is no brake bias issue, the ABS does not kick in under heavy braking as some suggest, and the car stops on a dime!!! I did not perform the install so I cant comment on the technical side of what exactly needs to be done inorder to fit the calipers. I posted pics of the finished product this past summer for those of you that may want to see them....It is a very cost effective way to improve your braking without spending huge coin on the aftermarket brands...(which you probably don't need unless you're tracking the car). Also,I did add SS lines all around and went with drilled an slotted rotors with Hawk ceramic pads...Esthetically, I love the look as it fills in the huge gap present with the OE rear brakes, especially when you have 19" rims...
It sounds like he did not have any problems with this mod.
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
hmmm...very interesting...it is possible to over analyze things....I agree as long as the car is for street only it just might not be an issue....except when driving on icy roads!
I have still not had any issues with this mod...There are several vettes here in the Toronto area with this mod, and to my knowledge there have been no issues. I do not track my car, but even with the added HP I have had no problems with braking and the ABS works fine
The guy I know who did this road races in NASA, and is one of the faster guys in the TTU class in this region. He runs full aero, of course, which most cars do not. His base car is a C5, though it runs an LS7 now rather than the original motor.
His comments were that he lost the parking brake (which on a race car, we don't use anyhow) because front rotors don't have a place for it and that while the ABS still works, it's a bit different than it was before. He used the RF caliper on the LR and vice versa. He did not indicate that he changed the proportioning on the car. It's an interesting mod, and should I think it would fit within the rules for my class, I might give it a try.
Front and rear spindles are identical at opposite corners... Meaning RF=LR and LF=RR.
One could very easily install front brakes on the rear with just brackets, rotors and calipers.
Using front rotors on the back will not allow the E-Brake to work.
Not sure how to get around the proportioning, hopefully others can chime in.
If you look at the pics posted above they dont use the front rotors. They retain the rear Z51 rotors. Which "should" mean you retain your parking brake.
You are partially correct. We used a C6 Z51 rear rotors to retain the parking brake function ( C5 brakes are all identical whether you have a base car, Z51 or Z06 )...and no proportioning valve is required...
Sry that's what I was saying lol. I have C6Z51's already so all I have to do is put my stock ones back on the rear lol. So this is a free mod for me
