Stock Wheel Stud exposed thread? Lug questions...
Old Apr 28, 2002 | 11:01 PM
MelloYellow's Avatar
MelloYellow
Default Stock Wheel Stud exposed thread? Lug questions...
How much length of the stock thread is exposed on the rear studs? Anyone have a change to measure this? Or.. how long/deep is a stock lug nut?
My studs are ARP style 1" longer and I want to make sure new lugs from McGard or Gorilla will fit. I think the aftermarket lugs are 1.5" deep?
Old Apr 28, 2002 | 11:20 PM
MelloYellow
Default Re: Stock Wheel Stud exposed thread? Lug questions... (MelloYellow)
If anyone has a stock open-ended lug from when it was removed and your OEM locks were installed... If you could measure the amount of thread on that stock lug nut, I'd appreciate!!
I threw mine out. ;)
Thx!
Old Apr 29, 2002 | 11:17 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My ruler is calibrated in mm, but here's some numbers:
OAL of stock lug nut, top to bottom: 26mm
Outside threaded area: approx 9mm long
Bottom of outside "cone" to top of outside threads: approx 14.5 mm
Inside threads look like they stop at the same point, so bottom of cone to top of inside threads also approx 14.5mm
When installed on the car, these nuts are about 1mm longer than the studs on the FRONT wheels.
On the REAR wheels, the studs stick out through the nuts by about 1mm
Hope this helps.
[Modified by Gearhead Jim, 9:20 AM 4/29/2002]
Old Apr 29, 2002 | 11:23 PM
MelloYellow
Default Re: Stock Wheel Stud exposed thread? Lug questions... (Gearhead Jim)
Thanks. We decided we'll measure using the open ended lugs. We'll use open ended lugs as a guide and saw off any excess length on the racing stud after I take off the spacers. Depends how the Fikse pad height comes out vs. stock also. Then we'll use a McGard or Gorilla style lug over the chopped race stud.
Hope we find some blades that can cut these hardened 190kpsi studs, LOL!
To Stock Wheel Stud exposed thread? Lug questions...
