Wheel Sizes and Flares
How wide can you go with the stock panels and not have the wheels poking out front underneath?
Are you after cosmetics or function ??
You pushing enough hp to spin a 325-345 ??
Heres what a (19x12 & 18x9.5) C6 ZO6 wheels look like on a C5 ZO6 with out flared quarters;
And about the front fender....it depends on your tire choice. 285/275 will be just about flush or a ch over.
@@wheel sizes@@
A C5 ZO6 18x10.5 has a 8.033" back space - 10.5" = 2.17". Thats how much will be extended past the face of the brake rotor.
And the C6 ZO6 19x12 has a 8.82" back space - 12" = 3.18". Thats how much will be extended past the face of the brake rotor.
So 2.17" - 3.18" = 1.01" difference. And FYI, the C5Z wheel sets about 1/4" inside the fender lip. Meaning a C6 ZO6 rear wheel will stick out about 3/4" of an inch to 1". As the picture above shows.
If this is going on a C5Z then a 1/2" spacer will be needed to clear the rear brake ducts.
Heres a thread I started last year when I was going through the same thoughts.
http://forums.corvetteforum.com/c5-g...r-fenders.html
This should get you started.....let me know if theres anything esle I can help you with..
Thanks....
