looking for larger capacity Oil filter
Old Aug 14, 2011 | 10:30 PM
futuretech's Avatar
futuretech
Default looking for larger capacity Oil filter
Looking are a larger capacity than our small stock one to collect stuff after engine rebuild. Recommendations
Old Aug 14, 2011 | 10:40 PM
NatB's Avatar
NatB
Why? Unless you are going to re-locate the oil filter, I don't think a larger filter will fit (you certainly do not want a longer one- it may hit something).
The stock size is IMHO fine.
Old Aug 14, 2011 | 10:59 PM
lucky131969's Avatar
lucky131969
I'm certainly familiar with break in oil, but I've never heard of a break in filter..............
Old Aug 14, 2011 | 11:04 PM
imavettegirl's Avatar
imavettegirl
stock filter will be just fine for break in.
Old Aug 14, 2011 | 11:27 PM
cptinjak's Avatar
cptinjak
Just get some cheap ones and change the oil a few times?
How much "stuff" are you planning on needing to catch!!??!
Old Aug 15, 2011 | 07:16 AM
AU N EGL's Avatar
AU N EGL
and magnetic drain plug,
get some Joe Gibbs new engine break in engine oil.
Old Aug 15, 2011 | 09:03 AM
crainholio's Avatar
crainholio
If you just want to run it in the garage, not driving it on the street, a truck filter will do. It will extend below the oil pan so no driving lest it get ripped off the engine.
Look up a Chevy truck of same model year as your car and you should be all set.
I'd recommend a FilterMag or similar magnet on the filter to assist in catching ferrous throwoff metal.
Old Aug 15, 2011 | 09:08 AM
dougbfresh's Avatar
dougbfresh
A few other guys that have tried this had BAD experiences when the low hanging filter got torn of on something.
Old Aug 15, 2011 | 09:15 AM
crainholio's Avatar
crainholio
It's an old-school practice, based on knowledge that the additional filter media surface area will flow more oil volume than the smaller normal filter.
If done using a high-quality filter with low-micron filtration media, it's probably the right thing to do. At worst, it accomplishes nothing. At best, it protects the engine during initial break-in. Can't possibly hurt.
All engines, no matter how precisely built, throw off more metal during break-in and it would not hurt to take steps to manage it. New rings riding a freshly honed cylinder wall will kick off iron in relatively large quantities, for example. You want that out of the oil.
I use a big-$$ synthetic media filter like K&N, Mobil-1, or more recently a Royal Purple filter sized for truck applications and place my FilterMag on its casing, crank the engine and let it run while verifying no leaks or other issues exist. Run the engine up to temp at ~2000 RPM (gotta love EFILive for bidirectional PCM control) and then let it idle for a bit at operating temp. Shut down, change the filter back to the normal car application (still a big-$$ piece) and put the FilterMag back on, then drive it normally for the rest of the 500mi break-in. Oil & filter change after that, then it's business as usual.
crainholio's Avatar
crainholio
Yup, see my comment on "no driving" w/ the truck filter on the engine. Bad juju.
Old Aug 15, 2011 | 02:17 PM
bighank's Avatar
bighank
Default I used a Caddy filter for one time in my C5 about 1 inch longer
It has the same thread size as the C5 but is longer. But I worried about hitting something on the road. Would suggest you use a regular filter and then change it after say 10 hours driving.
Old Aug 15, 2011 | 02:29 PM
cdkcorvette7's Avatar
cdkcorvette7
Regular filter should be fine. If you're really concerned put one of these on it: http://www.shopfiltermag.com/
I have a friend that swears by these.
To looking for larger capacity Oil filter
