Lowering A 97 C5
Old Apr 29, 2002 | 10:48 AM
WITVetteSC's Avatar
WITVetteSC
Default Lowering A 97 C5
Which is the best way to lower a C5:
Bolts and Bilstien shocks? or Install a set of fully adjustable coil overs?
I'm planning a 19/20 setup. Any help would be great.
Old Apr 29, 2002 | 10:25 PM
kwik8racr's Avatar
kwik8racr
Default Re: Lowering A 97 C5 (WITVetteSC)
Depending on how low you want to go, you will be able to lower your car about an 1" using the stock bolts. If you go to the tech tips section it will tell you step by step how to do it, very easy. If you are going 19/20 setup you should be able to get it low enough this way.Do not cut the bushings in the rear, there is no need to.I would recomend the Bilstien's also. In my opinion, coil overs are way too much money. If you do it the the way I said above all it will cost you is the price of the shocks(around$270).If you need more help you can e-mail me. :cheers:
Old Apr 30, 2002 | 11:05 AM
WITVetteSC's Avatar
WITVetteSC
Default Re: Lowering A 97 C5 (kwik8racr)
Thanks for the help. Is your car lowered with just bolts? If so, how much is it lowered?
Old Apr 30, 2002 | 11:16 AM
JoeCon's Avatar
JoeCon
What is the disadvantage of cuting the bushings? will this be counter-productive for drag racing?
Old Apr 30, 2002 | 12:06 PM
GR8-LIFE's Avatar
GR8-LIFE
WOW Kwik8racr, you car is low!!! Perhaps too low for me but what did you do to get it that low?
Old Apr 30, 2002 | 12:12 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Lowering A 97 C5 (MarkFLC5)
Check the sig! :cool: Keep in mind that I have 30 series tires so my fenders look higher above the tires than the car actually is. I want my suspension to be able to travel.
[Modified by Shinobi's97, 10:17 AM 4/30/2002]
Guest
Guest
Posts: n/a
Tech tips as mentioned above are a great resource. https://www.corvetteforum.com/techti...D=27&TopicID=1
Here is the direct link!!!
[Modified by nitrosuzie, 11:13 AM 4/30/2002]
To Lowering A 97 C5
