InterShaft replacement?
Old Aug 19, 2011 | 03:06 AM
IAIA's Avatar
IAIA
Default InterShaft replacement?
So, the clunk in my steering column has been diagnosed as needing a new I-shaft or Intershaft. Personally, I'm thinking maybe the joints just need tightening...but of course the dealer says otherwise. Anyone have any experience with this? And, how would I tighten the upper part (the lower part is exposed fairly well; the upper end is under the brake booster, I think).
Thanks.
Old Aug 19, 2011 | 09:44 AM
cdkcorvette7's Avatar
cdkcorvette7
Don't know if this helps you or not. I found it when I was looking into what it would take to replace the steering wheel position sensor...
http://forums.corvetteforum.com/1561060053-post11.html
Also, evidently there are two part numbers for that shaft; one is an old version you don't want. Never heard of this before, but here you go...: http://forums.corvetteforum.com/c5-t...ing-shaft.html
Old Aug 25, 2011 | 03:09 AM
IAIA's Avatar
IAIA
Wow. That post about the correct part number goes WAY back!
Thanks.
They put in the correct number. I think there's still a clunk, though. Just picked it up tonight. Well, left $500 there, but got my car back.
To InterShaft replacement?
