Quick Axle Seal Question
Old Aug 20, 2011 | 10:34 AM
DAC350's Avatar
DAC350
Default Quick Axle Seal Question
In the middle of replacing my diff cover o-ring and adding the new gm sealant. Surprisingly enough the actual axle seal is not leaking, just the diff cover. I've removed the axle and had a quick question. Even though my seal is not leaking, do I still need to replace it since I removed the axle? Should the seal be replaced every time you take the axle out? I just started thinking after I took it out that maybe it won't seal as well after removing the axle. Thanks for the help, back to the garage for now!
Old Aug 20, 2011 | 10:42 AM
bumble-z's Avatar
bumble-z
No the seal doesn't need replaced if it's not leaking.
The seal does not need to be replaced, when ever you pull the axles in or out.
If you are replacing the drivers side O ring with the differential still on it's cradle & the stud on the cover side, you must be having a fun time?
Good luck.
Old Aug 20, 2011 | 11:15 AM
DAC350's Avatar
DAC350
I am having a "fun" time, working on the stud now. Finding another nut to use. Should I grease up the axle before putting it back in the seal? Thanks so much for the info and help!
Old Aug 20, 2011 | 11:55 AM
bumble-z's Avatar
bumble-z
You might want to apply a small amount of heat to the "raised" area
where the stud goes into (when removing) & of course doubled nut.
If you have the axle completly out of the hub (wheel side), I'd clean the splines of the hub & axle real good with a wire brush/sand paper & then apply some good quality Motorcyle Chain lube to the spines of the axle & hub areas.
The axle spline that goes into the differential, could have a coating of motor oil or diff fluid prior to install.
Make sure that the cir clip is still attached to the axle coming out of the differential, before installing the the axle that you have just cleaned up & ready to install.
Good luck.
Old Aug 20, 2011 | 12:57 PM
LoneStarFRC's Avatar
LoneStarFRC
Good luck.
Good tips.
I also like to lightly coat the exposed threads on the end of the axle with anti-seize compound after torquing the large nut down. Also smear a very thin coat on the hub flange all around the wheel studs to keep the wheel from sticking to the flange.
Old Aug 20, 2011 | 05:36 PM
OneslowZ's Avatar
OneslowZ
if you have everything out and your in there replace the seals. they are not expensive. cant hurt.
Old Aug 28, 2011 | 10:09 PM
DAC350's Avatar
DAC350
Thanks for the help all! Just wanted to note for anyone using search and you find this post. Trust me, heat up the stud to get it out of the diff cover. I spent way too long trying to get it out without it, but then I heated up the area where the stud screws into the cover and snap (in a good way) the stud came right out!
Old Aug 28, 2011 | 10:30 PM
bumble-z's Avatar
bumble-z
Hey, glad you took my advise.
For those that dont own a "pencil torch", this is a job that is perfect
for using one for heating up a small area without over heating a larger area.
To Quick Axle Seal Question
