Oil pressure sensor - voltages @ x psi?
Old Aug 21, 2011 | 02:38 AM
RX-Ben's Avatar
RX-Ben
Default Oil pressure sensor - voltages @ x psi?
Anyone have a few data points of where the pressure is at various voltages?
Thanks.
Old Aug 21, 2011 | 11:11 AM
lucky131969's Avatar
lucky131969
Thanks.
I've never seen a plot. You could create your own, based on the min/max voltage in the service manual.....and let excel fit the data points you want to see.....then compare that to your actual readings. In any case, you need to start out with a good sensor, to verify your assumption of a linear relationship.
