A/C Problem
Old Aug 23, 2011 | 02:43 AM
enokcud's Avatar
enokcud
Default A/C Problem
My air condition system smells like exhaust fumes any one have any idea what could cause this to happen?
Old Aug 23, 2011 | 04:52 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
An exhaust system leak.
Old Aug 23, 2011 | 09:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If you are sure its not a mildew type smell and it really is exhaust, I would be quickly looking at the exhaust manifold to pipe clamps to insure they are tight and no leaks there. Exhaust fumes from there, can be drawn up into the fresh air inlet.
Old Aug 23, 2011 | 09:59 AM
rebelheart's Avatar
rebelheart
Are you in normal mode?If so, you are drawing air in from outside the cabin.Maybe you have an oil leak that could be smelling,or you are simply smelling other cars exhausts.If you are smelling it in recirc,it probably is not exhaust fumes you smell.
Old Aug 23, 2011 | 10:02 AM
lucky131969's Avatar
lucky131969
Has your oil pressure sensor been changed.....by cutting a hole in the cowl?
Old Aug 23, 2011 | 11:56 AM
enokcud's Avatar
enokcud
yes it looks like it has.
Old Aug 23, 2011 | 12:03 PM
lucky131969
If it was not sealed up well, that is most likely where the engine bay fumes are being introduced into the cabin.....as that is the fresh air intake with a hole in it.
Old Aug 23, 2011 | 01:00 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Good catch and drag....
For me... a beer and Burrito lunch and the AC on recirculate can case my exhaust fumes to get recirculated. Sorry
Bill aka ET
To A/C Problem
