You need to use LS2 rails, but you need to make sure you're injectors fit the cups, and I believe they are too short to reach thier seats without modification. You also will need a LS1 to LS2 wiring harness adapter. It's not a very good mod for your car, IMO. Do you have a returnless fuel system? If you haven't already bought it, you're better off with a LS6 mani, or FAST, which'll need the harness, but uses your fuel rail/injectors. (FAST 90). I don't know about the newer Wilsons.
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
fuel rails for an LS2 and injectors I can get. LS6 intakes don't take 90mm TB's and FAST 90's are far and few between. Plus anyone that has one for sale, used, still wants an arm and a leg for them.
So with that said, thanks for the input and it looks like I need to chase down some LS2 fuel rails, harnesses and injectors.
for 300 bucks TBIS will put a 90mm nozzle on your LS6 intake. Then you have a better flowing intake with the throttle body size you are wanting.
