C5 Speedometer
Old Aug 28, 2011 | 01:09 PM
tombobbitt's Avatar
tombobbitt
Default C5 Speedometer
The Speedo on my 2003, C5 is not working. The needle is all the way to the right past 200mph. It does not move. I just replaced the AC Heater Control in the dash and everything works fine (except the speedo). Cannot believe the two are connected. Tach works.
Any advice would be appreciated.
Old Aug 28, 2011 | 06:32 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Was it working before you replaced the HVAC control?
Old Aug 28, 2011 | 08:17 PM
tombobbitt's Avatar
tombobbitt
Yes, I think it was. I did not notice it wasn't working until I drove around the block to see if the HVAC was working.
Old Aug 28, 2011 | 08:59 PM
dgrant3830's Avatar
dgrant3830
Other than something at the speedometer connector back on the differential...I'm truly not sure what to suggest. At least make sure that connector back there is plugged in. I think you'll need the help of Bill Curlee, Lucky131969 or 8VETTE7
Old Aug 28, 2011 | 09:45 PM
tombobbitt's Avatar
tombobbitt
Thanks for you input. I will contact them tomorrow.
Old Aug 29, 2011 | 05:29 PM
tombobbitt's Avatar
tombobbitt
I made a visit to my mechanic who works on my car when it is something I cannot fix. He said that the speedometer and tach, both cycle whenever the car is turned on. The speedo may have cycled at the wrong time and got stuck. He pounded on the upper dash at the same time he turned the car to on. The speedo returned to its proper position and seems to work fine. Thought I would share this with everyone.
Old Aug 29, 2011 | 06:01 PM
lucky131969's Avatar
lucky131969
I think I know this mechanic.....is his name Arthur Fonzarelli?
Old Aug 29, 2011 | 06:13 PM
SaberD's Avatar
SaberD
i was gonna say take your foot off the gas happy motoring!
Old Sep 6, 2011 | 04:10 PM
c4vette92's Avatar
c4vette92
St. Jude Contributor
Default speedometer
any ideas if pounding does not work ? new cluster ?
To C5 Speedometer
