AC pipes icing up
Old Aug 28, 2011 | 04:49 PM
Jet-Jock's Avatar
Jet-Jock
Default AC pipes icing up
I read some other posts about this issue on what seems to be this cause/remedy.
Seems like after about an hour of running at cruise the AC system operation goes down to about a 10% efficiency that is hardly no vent output, a faint gurgling sound and barely cool at lowest temp setting. When I stop and inspect, the larger pipe across the firewall with large brass fitting (I need to look up the proper names) and the smaller line with the ports on it are solid ice. Once the ice melts or if I turn off the AC while driving for about 15 minutes and cycle it back on it starts to work ok again. For normal short runs, the AC gives no indication of a problem and will freeze the occupants set at 77°F. Albeit I live in a very humid environment, seems like I'm see more frequent fogging of the windshield over the defrost vent with the AC on.
I've also noticed there is a difference in the general tables for the specific ambient temperature provided on the refill instructions vs. the tables in the FSMs.
What do you all suppose is the issue here?
Old Aug 28, 2011 | 06:30 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would suggest starting by checking the udders and insure they are draining condensation and not plugged up.
Old Aug 28, 2011 | 07:22 PM
Quick Draw's Avatar
Quick Draw
I had this problem on another car (not a Corvette) and the problem was low freon.
Wouldn't hurt to have an AC shop check yours.
Old Aug 28, 2011 | 08:33 PM
redman0204's Avatar
redman0204
yea low refrigerant or pluged expantioon valve .
Old Aug 28, 2011 | 08:55 PM
Jet-Jock's Avatar
Jet-Jock
The table on the refill bottle says for example a 90°F ambient temperature, the low side should read 45-55 psi, for a 86-95°F ambient temperature the FSM says for above 50% humidity low port pressure should be 30-35 psi. That's quite a bit of difference if you ask me, wonder which is correct?
Yeah I need to take it to an AC service place...I'm one that likes to have an idea what the problem is before taking it in. LOL
Old Aug 29, 2011 | 06:23 AM
Cybermind's Avatar
Cybermind
95% of the time, AC system icing is an indication of low freon levels. I would go for a recharge.
Old Aug 29, 2011 | 09:19 AM
rebelheart's Avatar
rebelheart
Old Aug 29, 2011 | 09:33 AM
Jet-Jock's Avatar
Jet-Jock
Yeah not having much luck with AC systems, the house AC is doing the same thing as of late last night. Froze up solid no air coming out vents and pipes froze. AC guy this morning said low on freon so they have to wait for it to melt then they can service it. So wow even after several hours it's still froze. You'd think in this heat and humidity it wouldn't last! So both my system are low on freon. They said my cars' AC is probably low too I asked them just for grins.
Old Aug 29, 2011 | 10:47 AM
bighank's Avatar
bighank
Default I would replace the orfice tube as mine caused poor cooling
Icing probably low freon. I had proper charge and still had poor cooling.
Replaced orfice tube and rtecharged. That was it.
Old Aug 29, 2011 | 12:19 PM
Jet-Jock's Avatar
Jet-Jock
I think that's the service I'll call around for, replace the orifice tube, vacuum and recharge.
Now to find out which is better the dealer or a stand alone AC shoppe.
To AC pipes icing up
