Please Help
Aug 29, 2011 | 11:12 AM
Please Help
I have a 2000 corvette. Sometimes when I go to start the car it will just spin over and not start. Sometimes it takes about 3 times trying to start the car to get it to start. Sometimes it starts on the first time? I turn the key on and let the fuel pump cycle and it does correctly. Once the car starts it never messes up at all. Runs perfect. Any ideas what it could be. I called the dealership and they told me the fuel filter was $134.00. Is there something special about this filter, could that be my problem?
Aug 29, 2011 | 11:18 AM
Any codes? What's the fuel pressure when this happens?
Aug 29, 2011 | 11:19 AM
Quote:
Originally Posted by
hatcher1986
On a 2000, the fuel filter and pressure regulator, are one assembly. Yes, it is one possibility. Install a pressure gauge at the rail, and check pressure/bleed down.
Also, post your codes.
Aug 29, 2011 | 11:20 AM
No codes. Havnt checked the fuel pressure. Do u think it could be the fuelmpressure since the car runs perfect after it starts?
Aug 29, 2011 | 11:21 AM
What should the pressure be while starting the car or during the starting cycle?
Aug 29, 2011 | 11:22 AM
hatcher1986
Check the fuel pressure with a gauge. Key on (not started) 55-61 psi. Pressure should hold, not drop off sharply.
Aug 29, 2011 | 11:24 AM
What should the pressure be during the start cycle, and while turning the car over?
Aug 29, 2011 | 11:27 AM
lucky131969
Ok man thanks for the help. So if it's low should I change the pump of filer assembly?
Aug 29, 2011 | 12:11 PM
hatcher1986
On a 2000, the pump and filter/regulator, are two separate assemblies. First you have to determine what you have, before you can take the next step.
Aug 29, 2011 | 12:38 PM
lucky131969
Check the fuel pressure with a gauge. Key on (not started) 55-61 psi. Pressure should hold, not drop off sharply .
OP: Listen to what Luck is saying here. This is important.
Aug 29, 2011 | 12:50 PM
Ok.... Well since the pump, and the regulator/filter are two different parts, if the fuel pressure drops off or is low, which should I change first?
Aug 29, 2011 | 12:55 PM
hatcher1986
I can guide you, but I'm not a "parts changer". I prefer isolation and troubleshooting. If the pressure drops off, it could be a few things:
1) Regulator
2) Pump check valve
3) Leaky injector
If the pressure holds, but is low :
1) Filter/regulator
2) Pump
Aug 29, 2011 | 12:59 PM
Alright hopefully I'll get a few minutes to check the pressure when I get off work tonight. Thanks for the help. Hopefully I'll be able to let u kno what the pressure is tonight and go from there.
