Help diagnose- Bogging problem at part throttle
Old Aug 29, 2011 | 10:02 PM
Unoid's Avatar
Unoid
Cruising
Default Help diagnose- Bogging problem at part throttle
Occasionally when driving my 98kmi h/c/i C5, I will accelerate no matter the gear and it will no go faster, it will make a gurgling nose, like a muffled water bong. if I let off the gas right away and get back on it's just fine.
I'm thinking a sticking throttle body? Haven't taken off the intake to see if its caked with carbon.
I'm considering getting it re-tuned as well to make sure the fuel is spot on. (carbon out the tailpipes is ridiculous.)
anyone had this happen or know whats my problem before I go spending $?
Old Aug 29, 2011 | 11:03 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Check the condition of your plugs and wires and report back with your findings.
-RR
Old Aug 29, 2011 | 11:04 PM
Unoid's Avatar
Unoid
Cruising
-RR
I can do that, but I'm pretty sure the plugs are somewhat newer. Full throttle the cars is perfect.
Old Aug 30, 2011 | 08:32 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Pull your codes and post them.
Old Sep 2, 2011 | 11:29 PM
Unoid's Avatar
Unoid
Cruising
Problem seems to be worse when cold engine, starts a 2K
Ordered new plugs n wires. contemplating new injectors. Going to get re-tuned.
Seems to be getting worse. I am unsure why it would bog down worse and worse now.
Old Sep 3, 2011 | 12:32 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Have your tuner check if the front O2 sensors are switching correctly.
-RR
To Help diagnose- Bogging problem at part throttle
