The traction control will not turn off on my2000 corvette.Also the select ride switch does not seem to work.The key fob loses program right after I reprogram it.What should I check first?
Check the codes. There's a code reader built into the DIC on your car. Search for it and you'll find many answers.
Problems is, your system is disabled because of a problem, most likely.
ps. I'm not an expert as fixing them but finding out how to diagnose anything on these cars is available right here on the forum!
