97-00 TSP headers on 01?
Old Aug 31, 2011 | 07:23 PM
dheide's Avatar
dheide
Default 97-00 TSP headers on 01?
So I stupidly bought a set of 97-00 tsp headers for my 01...Cost $250 (at least I wont be out to much!) What am I gona have to do to put these on? Is it even possible? What all will I need to modify to make it work. Thank guys as always
Old Aug 31, 2011 | 07:40 PM
MawneeC5's Avatar
MawneeC5
Your air tubes and oil dipstick won't line up. I'm running early year headers on my 03. I simply removed the air tubes(block off plates) and the dipstick just had to be bent over a bit.
Old Aug 31, 2011 | 07:50 PM
dheide's Avatar
dheide
How did you block them off and what brand are you running? Thanks!
Old Aug 31, 2011 | 08:43 PM
baxsom's Avatar
baxsom
you must use your 01 tube, in fact us 00 guys that buy tsp headers have to get 01 dipstick tubes to make it all work.
air tubes do not matter because tsp headers do not have the attachment hole that they would bolt to. if you get tsp headers you must remove all AIR stuff and have it programmed out of the PCM or you will get a CEL. They are very easy to install.
Old Sep 1, 2011 | 12:02 PM
Matt@Texas-Speed's Avatar
Matt@Texas-Speed
Premium Supporting Vendor
That is UNLESS he bought a used set of the old design from back when we did have the option for air fittings.
__________________
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
Old Sep 1, 2011 | 12:28 PM
KillerB04's Avatar
KillerB04
Shoot, if they dont fit ill take em off ur hands. Just a thought
Old Sep 1, 2011 | 02:34 PM
MawneeC5's Avatar
MawneeC5
I'm running Bellangers For block off plates I just cut pieces of metal using the gasket as a template. Then bolt them to the headers with the gasket. Then you can remove the air tubes and pump from the car altogether. You will have to get it tuned to remove the code for them though.
One thing to note. A few people who have used block off plates like this have had problems with the tube on the headers getting hot and cracking around the welds. Though personally I've run like this on a few cars and never had a problem.
To 97-00 TSP headers on 01?
