Which 315 Drags Radials to Replace Nittos with?
Old Apr 30, 2002 | 06:02 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Which 315 Drags Radials to Replace Nittos with?
I have the Nitto 315-17 drag radials mounted on Zr1 rims now. However they absolutely suck at hooking up for me! I noticed several brands of 315-17's at tire rack. I assume that BFG's are the one's to go with. Does anyone know if the BFG Drag Radials at Tirerack are the correct ones? They sure look like more of a street tire than drag radial...
Anyway the poll is here in case someone can think of a better tire. Thanks.
Old Apr 30, 2002 | 06:36 PM
vstella's Avatar
vstella
Default Re: Which 315 Drags Radials to Replace Nittos with? (C5-VERT)
I'm surprised your having traction problems with the Nitto's. I have the street version 555's and they are a great street tire but i was consifdering a CCW wheel and Nitto 315 x17 DR. Are you heat cycling the tire in the burnout? Are they hot enough ? :confused:There are many CF members have used this DR with success :rolleyes: Why are you have such bad luck with these DR's?
Old Apr 30, 2002 | 06:57 PM
C5-VERT's Avatar
C5-VERT
Default Re: Which 315 Drags Radials to Replace Nittos with? (vstella)
Yes I am heat cycling the crap out of them. I am also running 15lbs of pressure. The only thing I can think of is the track is not prepped very well. After all every time I have run it has been import night... :U
Old Apr 30, 2002 | 07:03 PM
Silver TT's Avatar
Silver TT
From what I have read, the BFGs hook considerably better than the Nittos, but also are TERRIBLE :eek: in the rain. They also wear out about 2x as fast as the Nittos.
Nittos are the better all around tire for handling, acceleration, and wet driving. But if you are looking for the closest thing to a slick, without it being a true slick (ET Streets, Drags) the 315 BFG is the way to go.
Good luck.
DAn
Old Apr 30, 2002 | 08:30 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
your psi might be too low. I run bfg's with 21 psi
Old Apr 30, 2002 | 08:57 PM
Power Shifter's Avatar
Power Shifter
Default Re: Which 315 Drags Radials to Replace Nittos with? (REDGAR)
I can't tell from your sig if your car is stick or auto. The nitto's stiffer sidewall just doesen't work as well on my stick car's as well as they did on my automatic's. BFG's are easyer to work with but don't last very long. Ric
Old Apr 30, 2002 | 11:44 PM
C5-VERT's Avatar
C5-VERT
Default Re: Which 315 Drags Radials to Replace Nittos with? (Power Shifter)
I have an MN6 and I have tried running with numerous tire pressures.
Ok, can someone tell me if the BFG's that are available on TireRack are the correct ones. It just seems to me like the tread looks more like a street tire than a drag radial.
Old Apr 30, 2002 | 11:50 PM
Power Shifter
BFG only makes one style drag radial in the C5 sizes. Get the right size get the right tire. Ric
Old Apr 30, 2002 | 11:59 PM
C5-VERT's Avatar
C5-VERT
Thanks :cheers:
Old May 1, 2002 | 03:56 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I run BFG, 18 PSI got from the Tire Rack!
Old May 1, 2002 | 04:08 AM
bruce1's Avatar
bruce1
Default Re: Which 315 Drags Radials to Replace Nittos with? (wallstAL)
AL:
Why not join us at Carlsbad on the next Sunday event?
Looks like you are ready!
:eek:
Old May 1, 2002 | 04:31 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Which 315 Drags Radials to Replace Nittos with? (bruce1)
AL:Why not join us at Carlsbad on the next Sunday event?Looks like you are ready! :eek:
Far from being ready, still tuning and a few other issues!
Old May 1, 2002 | 09:04 PM
C5 Frank's Avatar
C5 Frank
I've got the 315-17 nitto drags on my Cobra (414rwhp).... They hook great... for a street tire. But they are not slicks! As long as you keep that in mind you will be happy. I picked the Nittos because they are on the car always... the BFGs are REAL BAD in the rain! It rains here in FL all the time.
Old May 3, 2002 | 12:15 AM
C5-VERT's Avatar
C5-VERT
Default Re: Which 315 Drags Radials to Replace Nittos with? (C5 Frank)
BFG's are on the way! I will follow up with results in a couple of weeks...
Thanks :cheers:
Old May 7, 2002 | 03:15 AM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
OK what is the 'one size drag radial' that BFG makes in corvette size?
315x30x17?? 315/35/17?
Old May 7, 2002 | 04:48 AM
C5-VERT's Avatar
C5-VERT
Default Re: Which 315 Drags Radials to Replace Nittos with? (AVETTE)
The one I am going with is 315/35/17
Old May 7, 2002 | 08:36 AM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
BF's are the way to go no doubt . However , listen to the previous post's about very bad traction on wet pavement.
Old May 7, 2002 | 08:39 AM
C5-VERT's Avatar
C5-VERT
Default Re: Which 315 Drags Radials to Replace Nittos with? (FrankUrbinati)
Thanks guys for the help. Of course wet roads do not apply as these will only be used at the strip. Hopefully I can try them out here in the next couple of weeks...
To Which 315 Drags Radials to Replace Nittos with?
