A California friendly cam?
Old Sep 6, 2011 | 11:59 PM
Laser Guided's Avatar
Laser Guided
Default A California friendly cam?
Living in CA has it's ups and downs, obviously one of the downers being smog. No LT headers or huge cams. So my question is this, what do you guys think would be the biggest cam that I could pull off without having to worry about smog at all? Now obviously it isn't going to be that large, but do you think the largest CA friendly cam would still require valvetrain upgrades as well?
Thanks for any input.
Old Sep 7, 2011 | 12:05 AM
thetaxman's Avatar
thetaxman
Old Sep 7, 2011 | 06:51 AM
AU N EGL's Avatar
AU N EGL
224/ 228 581/588 113+0
Old Sep 7, 2011 | 07:33 AM
airbrush1's Avatar
airbrush1
My question would be..... How is the CARB guy going to give you an issue with a cam if you have no codes and it passes visual inspection?
serious question... its not a part he can see to give you **** about
Old Sep 7, 2011 | 10:04 AM
SDLS1Rider's Avatar
SDLS1Rider
California smog inspections currently have a sniffer. The overlap on a large cam allows unburned gasoline to exit the tail pipe. The sniffer picks it up and you can't register your car.
Old Sep 7, 2011 | 12:42 PM
airbrush1's Avatar
airbrush1
Ugh... Evil empire indeed!
Old Sep 7, 2011 | 02:47 PM
tlove32's Avatar
tlove32
That can would be iffy. Make it a 114 or 115 LSA and it would pass.
To the OP - get a supercharger (A&A or Maggie)....they're smog legal and make a ton of power
Old Sep 7, 2011 | 04:42 PM
R CRYSIS's Avatar
R CRYSIS
I ran a 220-224 on a 114 lobe center advanced the exhaust +3 with 581 lift. Car runs strong and passes smog with no problems. I have had to have it sniffed twice. It passed so well I was kinda disappointed because I think I could have got away with a little more but as hard as it is to install a cam on a C5 I guess it's better safe than sorry
Old Sep 7, 2011 | 05:37 PM
SDLS1Rider's Avatar
SDLS1Rider
Originally Posted by bill mcdonald
Are they still doing the sniffer here?
I thought the new system rule was to plug in, and if it checked out, you passed?
I have to smog in nov.
I read a report that said they would start in 2013. Then when I was up at RPM Motors in Santa Clarita, Charlie said he expected the plug in to start in 2012 (Jan?). Time will tell.
Old Sep 7, 2011 | 05:43 PM
chaase's Avatar
chaase
St. Jude Donor '12
They have used the plugin method here in NY for a while and it is great. You can mod the call to the hilt. The car's computer says everything is fine and dandy and you get a new inspection sticker.
Old Sep 7, 2011 | 08:04 PM
baxsom's Avatar
baxsom
Fl,
no smog, no sniffer, no inspections, no sticker.
lots of smoking cars on the road with bad brakes and cracked windows.
Old Sep 7, 2011 | 08:45 PM
jonnyc's Avatar
jonnyc
my 224/224 114lsa passed with no problem.i've read people passing with a 230 cam but to be safe i wouldn't go bigger than a 228/228.it will have to be 114 lsa.
To A California friendly cam?
