'00 No Start, Codes Listed
Old Sep 7, 2011 | 09:48 AM
harrydunn's Avatar
harrydunn
Default '00 No Start, Codes Listed
Greetings. New to the forum. Car has been starting and running great in the 10 days I've owned it but refused to crank last night. Delco battery appears to be fine. Gauges sweep, all lights nice and bright, I can hear a clicking when I depress the clutch with key on, fuel pump comes to life. Tried to jump it and same result. I've read several posts but would like to know the best route to take before I start chasing dead-ends. It's not my daily driver so it can sit in the garage and think about what its done until I get it figured out.
I researched how to pull the codes and they are as follows:
58 SDM
B1001 H
U1064 H
80 RADIO
U1064 H
A0 LDCM
B2284 H
U1064 H
A1 RDCM
B2283 H
B2285 H
U1064 H
Thanks!
Mark
Old Sep 7, 2011 | 09:51 AM
dougbfresh's Avatar
dougbfresh
I'd check/clean the starter connections first.
Old Sep 7, 2011 | 10:47 AM
harrydunn's Avatar
harrydunn
Thanks for the reply. I'll check that out tonight.
I should also mention that the second key does not work either. Same behavior.
--Mark
Old Sep 7, 2011 | 11:50 AM
BigGun's Avatar
BigGun
Load testing the battery and checking those connections (clean and tight) first will be easier. The starter connections are a little harder to get at but will need to be checked if the battery is good.
Old Sep 7, 2011 | 12:14 PM
harrydunn's Avatar
harrydunn
Battery connections are clean and tight. If it was a bad battery, wouldn't attempting to jump start it this morning have cranked it up if all else was working properly?
Thanks.
Old Sep 7, 2011 | 02:10 PM
lucky131969's Avatar
lucky131969
Thanks.
Not necessarily. I've seen batteries with a shorted cell, and car would not jump start.
Old Sep 7, 2011 | 02:14 PM
harrydunn's Avatar
harrydunn
I'll pull the battery tonight and have it tested. Is it possible to get to the starter from above to look at the connections / hit it with a rubber mallet?
Thanks.
Old Sep 7, 2011 | 02:21 PM
lucky131969
Thanks.
Nope. If you are going to inspect the wiring to the starter, take a meter down there with you, and check for 12 volts to the purple wire(terminal S), when the key is turned to start.
Old Sep 7, 2011 | 07:15 PM
harrydunn's Avatar
harrydunn
Had the battery tested and it is fine. Going to throw it up the air and look the starter over. Any suggestions after I check that out are greatly appreciated!
--Mark
Old Sep 7, 2011 | 11:27 PM
harrydunn's Avatar
harrydunn
Well, that's a little odd. Got underneath the car to check out the starter. Whacked it with a rubber mallet a few times first to see if that would solve anything. No such luck. Put a meter on it and was getting 12V in the start position. Tried to start it several more times while I pondered what to check next. About 30 minutes later, it decided it would start. I took it for a drive and stopped by the auto parts store to have them check the alternator. It was fine. I'm obviously somewhat confused but am assuming one of you guys will have an answer. I'm definitely not pronouncing the problem as fixed. Thanks for helping a new guy out.
--Mark
Old Sep 7, 2011 | 11:50 PM
shadowman1's Avatar
shadowman1
If you had 12 volts on the trip wire when you turned the key and still had 12 volts on the big wire at the same time I'd say your starter is bad.
Dave
To '00 No Start, Codes Listed
