im going to the track friday and just got my homemade drag pack all together, and i have the car lowered very far, and i figured i'd put it back up a lil bit for the track for weight transfer. is this too tall in the rear? it might also settle a little. i pulled it up about 15 feet and backed it back up. any input is appreciated! thanks
PRE-Z06
close
- Member SinceDec 2006
- LocationFort Worth, Texas
Liked:2,868 Times in 1,828 Posts
It's hard to say from that pic and if the car hasn't been driven after the suspension was unloaded, but it looks like you're running a 26" ET street from what I can tell. Not sure if you have a reference point of where you were or what stock is. I am lowered ~3/4" from stock all the way around to lower the drag yet keep the rake. I'd make sure the changes to suspension height didn't affect your alignment/contact patch depending on how drastic the change is. Like the screws, good luck at the track!
thanks. i think im gonna lower the rear a little bit more in the back and try to go up in the front a little and then take it for a spin and see where i'm at.
PRE-Z06
close
Quote:
No problem, I saw the pics in the other thread and it looked goodOriginally Posted by BuddhaZ06
Quote:
good deal, i'll try it out tonight at the track and adjust if necessary. thanks!Originally Posted by PRE-Z06
