1998 computer swap????
Old Sep 8, 2011 | 09:27 PM
ranman106's Avatar
ranman106
2nd Gear
Default 1998 computer swap????
Newbie here!!!!
The computer in my father's 1998 Vette is fried. Can I swap it with another 1998-2002 Vette? If so, what do I need to look for? What else needs to be changed along with it?
Thanks!!!
Old Sep 9, 2011 | 09:13 PM
ranman106's Avatar
ranman106
2nd Gear
If the service tags are the same, is that all I need to verify?
Old Sep 10, 2011 | 11:19 AM
corvettebob1's Avatar
corvettebob1
You can install a late model PCM in a 98 but the pin outs are different and need to changed.
And you will need a tuner to change the VIN in the new computer to match your car.
Really not worth the expense if the car is stock.
Old Sep 10, 2011 | 11:31 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You really need to attempt to get the proper PCM for your car as opposed to modifying wiring to get a newer one to work. You'll also need a dealer to program in RPO codes. Note that just replacing the computer, the car will not start up. A security relearn procedure must be accomplished first. If you can't find a new PCM, try a corvette recycler and see if you can get one that way for your year then have it taken to a dealer for installation and programming.
To 1998 computer swap????
