HELP - Brake Torque Specs!
I am leaving the stock calipers. Although I did paint them.
My question is, there are two different torque specs printed in the dealer service manual regarding tightening the brake caliper inlet bolt. (The one that connects the hose to the caliper.)
In the "Hydraulic Brakes" chapter, under "Brake Hose Replacement" it says to tighten the brake caliper inlet bolt to 37 lb ft.
But in the next "Disc Brakes" chapter, under "Brake Caliper Replacement" it says to tighten the brake caliper inlet bolt to 30 lb ft.
Which one do I do?
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
Which one do I do?
