start up display
Old Sep 10, 2011 | 01:35 PM
Vineyard Vett's Avatar
Vineyard Vett
2nd Gear
Default start up display
C5 no longer displays CORVETTE on start up. What wrong button did I push?
Old Sep 10, 2011 | 02:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That data is generated inside the IPC. If it were me,, I would check the input voltages (12VDC) with a meter and make SURE its actually the correct voltage, Module Ground, and if all those are good, take the IPC apart and make sure that the solder joints on the display are not defective (colder solder joints)
Do you get ANY dispay on the screen (DIC) ???
Old Sep 10, 2011 | 02:55 PM
BarryBum's Avatar
BarryBum
St. Jude Donor '10
that can't be changed to say a custom saying can it?
Old Sep 10, 2011 | 03:30 PM
Vineyard Vett
2nd Gear
Everything else displays, just doesn't read CORVETTE when you start the car as it once did.
Old Sep 10, 2011 | 03:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,, I would say thats a ROM issue inside the IPC.
NO,, the massage can not be changed. YOU can on a C6,,
To start up display
