Oil Pressure Sender
Tools and stuff we needed after cutting the hole. 2 zip ties for tieing the crossing hose back in the area. Dremmel Tool with 1/2 inch cutter wheel and a small saw with a handle. Mechanical finger for getting into the space. #27 metric deep socket, universal, extension, and a rachet, Long small straight screwdriver to hold the clip off the connector, with a long dent puller with a side puller to pop off the connector. If you have access to someone with a small hand they can reach in and remove the connector. We used the mechanical finger to start the new sending unit into the hole and then tightened it with the socket. I think that with 2 people you could probably do this in 20 minutes the second time.
